Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide will help to you access your viewfinder in your Nikon D40 and replace the viewfinder.
Выберете то, что вам нужно
Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
Use a spudger to keep the upper body separate from the printed circuit board.
Wiggle the plastic eyepiece out of the frame. This may require some force.
2 участников успешно повторили данное руководство.
