Nikon D500 Back Panel Removal
Выберете то, что вам нужно
    • Remove the Memory Card(s) from the camera
    • Remove the Battery from the Camera, and close the battery compartment cover
  1. Nikon D500 Back Panel Removal, Remove 2 exposed screws: шаг 2, изображение 1 из 1
    • Remove the 2 screws beside the memory slots, then close the cover.
    • Note: make sure to remove the memory cards first!
  2. Nikon D500 Back Panel Removal, Remove 2 screws under grip: шаг 3, изображение 1 из 1
    • Remove the 2 screws under the rubber grip part by peeling back the rubber grip
    • Try not to damage the double sided adhesive under the rubber.
  3. Nikon D500 Back Panel Removal, Remove 2 screws under rear grip: шаг 4, изображение 1 из 1
    • Remove the 2 screws under the rubber pad marked in red.
    • Try not to damage the double-sided adhesive under the rubber.
    • Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
    • Lift out the assembly panel, it should come free without much force.
    • May open the panel to release it.
  4. Nikon D500 Back Panel Removal, Remove top screw: шаг 6, изображение 1 из 1
    • Remove the screw above the viewfinder
  5. Nikon D500 Back Panel Removal, Remove the bottom panel plate: шаг 7, изображение 1 из 1
    • Remove the 4 screws holding the plate to the bottom.
    • Remove the bottom plate
  6. Nikon D500 Back Panel Removal, Remove screws from the bottom: шаг 8, изображение 1 из 1
    • Remove the 4 screws (1 was under the plate removed under the last step)
  7. Nikon D500 Back Panel Removal, Remove Screw under grip: шаг 9, изображение 1 из 1
    • Remove the screw under the grip, if it has not been removed doing a previous step
  8. Nikon D500 Back Panel Removal, Remove Screw on Left: шаг 10, изображение 1 из 1
    • Remove the exposed screw on the Left side
  9. Nikon D500 Back Panel Removal, Carefully remove the back assembly: шаг 11, изображение 1 из 1
    • Carefully pull the back plate off the camera
    • There are 2 ribbon cables that need to be disconnected from the main board to free the rear panel from the camera.
    • To release the cables by flipping up the tap on the side away from the cable
    • When reconnecting the cables, make sure the cables are fully seated before flipping the latch back down.
    • The black cable goes to the LCD (on the tilt screen), the other one goes to the buttons.
    • The black LCD cable does have less slack, so is easier to release first, and reconnect last.
Заключение
Еще один человек закончил это руководство.
Wolphin
Участник с: 11/11/19
1 795 Репутация
Автор 9 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 8
За последние 30 дней: 55
За всё время: 2,591
