Введение
Use this guide to replace the mirror box and viewfinder.
Выберете то, что вам нужно
Remove the following 5 screws securing the bottom cover to the camera body:
Four 6 mm J000 screws.
One 8 mm J000 screw (under lens mount).
Remove the following screws from the port area:
Two 3.5 mm J000 screws.
One 6 mm J000 screw (right above ports).
Remove the following screws that secure the back case:
One 6 mm J000 screw.
One 3 mm J000 screw.
Remove the following screws securing the left motherboard shield:
One 2 mm J000 screw (on the bottom).
One 3.5 mm J000 screw (on the back).
Carefully lift the tripod plate from the backside of the camera and slide out the grounding clip from under the lens mount.
Manually pop up flash by inserting a screw driver to the left of the viewfinder and pressing on the metal lever.
Remove two 6.5 mm J000 screws securing the viewfinder.
Remove the viewfinder cover.
Pull out ribbon cable from circuit asembly near front left of device.
5 участников успешно повторили данное руководство.
