Введение
In the chance that your circuit board stops working, this step-by-step guide will show you how to replace it. For soldering help, follow the How to Solder and Desolder Connections guide.
Выберете то, что вам нужно
Remove the five screws (13mm long, 6mm head) attaching the Base Cover using a Phillips screwdriver (Ph2).
Remove the two screws (13 mm long, 6mm head) attaching the Base Cover using a T10 screwdriver.
Carefully remove the second layer from the base. You will not need a screwdriver for this step.
Remove the 2 screws (13mm, 6mm head) connected to the plastic piece holding down the power cord.
Then remove the additional 4 screws (13mm, 6mm head) and 2 screws (11mm, 5mm head) securing the base.
Carefully lift the base up from the rest of the blender.
Cautiously desolder all the wires connecting the circuit board to the unit.
Carefully slide the circuit board free of the wires are place the new board in.
Solder the wires back onto the new board, keeping track of which wire goes where in order for your unit to properly function.
5 участников успешно повторили данное руководство.
14 Комментариев
Thanks for the post… this is helping me with my blender…. by any chance do you have a better picture of the resistor on the back of the circuit board… it seems to be a yellow blue blue gold sequence resistor… my board just burned that resistor and I am trying to find and replace just that resistor if possible… but I am not sure of the colors so I can locate the right now.
Anyone know the chip on this circuit board?? Proprietary I assume??
hi,, i need to know the reference of transistor with position Q2. in the main board BL770 , thanks.
