Введение
This is a guide for the removal of the back panel of the Nintendo 2DS. This guide will illustrate how to remove the screws attaching the back panel in order to access other parts of the Nintendo 2DS.
Выберете то, что вам нужно
Carefully pull the rear panel straight up from the device.
Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
Remove the cable from the connector
You can also detach the cable from the motherboard safely by flipping up the connector on the motherboard. Just don't forget to reattach. Some will find this tedious but may save time if you know what you're doing with said connectors.
I agree, this is what the guide i followed said to do and since I was disconnecting all the other ribbon cables it made perfect sense to do it that way.
Lin -
pay attention: my 2ds dropped it's lens covers at this step
Likewise, I used a tiny drop of glue to put the lens back in place. Take care not to dirty the lens.
The picture you have there has the camera lens ribbon installed upside down. The ribbon needs to be pointing down when you re-attach it not up.
Agreed, ribbon cable looks upside down in picture
11 человек успешно провели ремонт по этому руководству.
2Комментарии к руководству
The two top screws on the backpanel I cannot get out, I used the same screwdriver I used for every other screw.
Please help!
For those two screws that are on the top cap aren’t supposed to come out, if the do come out it means you’ve broken those screws. Also after unscrewing that top it should just slide up.
Can't take off the screw top left next to the battery. What type of screwdriver do I use and where can I find some?
Little Mac - Ответить
I used a husky with changeable heads, you could probably find one on amazon
Minecrafter Pig -
These screws aren't Phillips, they're JIS, if you use a Phillips head you can and will strip the screws, please update this as it can cause more harm to people's systems than good if they get stripped.
Sneakii - Ответить
yep. i stripped my screws
Persvicx -
The screws are 6.2mm long
Martin Samuelsson - Ответить
god I thought it was because I was repairing a sibling's ds that had something spilled on it (idk maybe that they didn't clean it good when it happened) but continued to struggle even with screws that looked fine... wish I had checked the comments sooner :/ Please like the above, update this guide! It sucks knowing that someone like me is also gonna probably miss this. I didn't get super far but well. I already stripped down some which sucks either way. Ironically, I noticed that using a size slightly smaller gets the job done better. Ironic in that you'd normally avoid that because it's more likely to strip with small bits scrapping the inside. But if you are real careful it can hang on and twist. I'd recommend just getting the JIS but maybe this might work for some- I also want to emphasize SLIGHTLY smaller phillips.
Alexandria.P - Ответить
