Nintendo 3DS Touchscreen Replacement
Выберете то, что вам нужно
  1. Nintendo 3DS Touchscreen Replacement, Loosen the rear screws: шаг 1, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
  2. Nintendo 3DS Touchscreen Replacement, Remove the rear cover: шаг 2, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement, Remove the rear cover: шаг 2, изображение 2 из 2
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
  3. Nintendo 3DS Touchscreen Replacement, Battery: шаг 3, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement, Battery: шаг 3, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement, Battery: шаг 3, изображение 3 из 3
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
  4. Nintendo 3DS Touchscreen Replacement, Lower Case: шаг 4, изображение 1 из 1
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is desinged to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
  5. Nintendo 3DS Touchscreen Replacement: шаг 5, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 5, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 5, изображение 3 из 3
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
  6. Nintendo 3DS Touchscreen Replacement, Circle Pad Joystick: шаг 6, изображение 1 из 1
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
  7. Nintendo 3DS Touchscreen Replacement: шаг 7, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 7, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 7, изображение 3 из 3
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
  8. Nintendo 3DS Touchscreen Replacement: шаг 8, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 8, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 8, изображение 3 из 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
  9. Nintendo 3DS Touchscreen Replacement: шаг 9, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement: шаг 9, изображение 2 из 2
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
  10. Nintendo 3DS Touchscreen Replacement, SD Board: шаг 10, изображение 1 из 1
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
  11. Nintendo 3DS Touchscreen Replacement: шаг 11, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement: шаг 11, изображение 2 из 2
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
  12. Nintendo 3DS Touchscreen Replacement: шаг 12, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 12, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 12, изображение 3 из 3
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
  13. Nintendo 3DS Touchscreen Replacement, Pry the Wi-Fi card up: шаг 13, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement, Pry the Wi-Fi card up: шаг 13, изображение 2 из 2
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
  14. Nintendo 3DS Touchscreen Replacement, Disconnect the Wi-Fi board: шаг 14, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement, Disconnect the Wi-Fi board: шаг 14, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement, Disconnect the Wi-Fi board: шаг 14, изображение 3 из 3
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
  15. Nintendo 3DS Touchscreen Replacement, Motherboard Assembly: шаг 15, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement, Motherboard Assembly: шаг 15, изображение 2 из 2
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
  16. Nintendo 3DS Touchscreen Replacement: шаг 16, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 16, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 16, изображение 3 из 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
  17. Nintendo 3DS Touchscreen Replacement: шаг 17, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement: шаг 17, изображение 2 из 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
  18. Nintendo 3DS Touchscreen Replacement: шаг 18, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 18, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 18, изображение 3 из 3
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
  19. Nintendo 3DS Touchscreen Replacement: шаг 19, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 19, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 19, изображение 3 из 3
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
  20. Nintendo 3DS Touchscreen Replacement: шаг 20, изображение 1 из 1
    • Remove the motherboard assembly from the rest of the device.
  21. Nintendo 3DS Touchscreen Replacement, Lower Display Assembly: шаг 21, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement, Lower Display Assembly: шаг 21, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement, Lower Display Assembly: шаг 21, изображение 3 из 3
    • Set the motherboard assembly down so that the lower LCD is side-by-side with the motherboard.
    • Use the tip of a spudger or your fingers to peel back the white tape covering the touchscreen ribbon cable connector.
  22. Nintendo 3DS Touchscreen Replacement: шаг 22, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement: шаг 22, изображение 2 из 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the touchscreen ribbon cable ZIF socket.
  23. Nintendo 3DS Touchscreen Replacement: шаг 23, изображение 1 из 3 Nintendo 3DS Touchscreen Replacement: шаг 23, изображение 2 из 3 Nintendo 3DS Touchscreen Replacement: шаг 23, изображение 3 из 3
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD power ribbon cable ZIF socket.
    • Pull the ribbon cable out of the connector with a pair of tweezers.
    • Grasp the ribbon cable as close to the connector as possible with the tweezers to avoid tearing it.
  24. Nintendo 3DS Touchscreen Replacement: шаг 24, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement: шаг 24, изображение 2 из 2
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the lower LCD data ribbon cable ZIF socket.
  25. Nintendo 3DS Touchscreen Replacement: шаг 25, изображение 1 из 1
    • Grasp the lower display assembly and pull it directly away from the motherboard.
  26. Nintendo 3DS Touchscreen Replacement, Touchscreen: шаг 26, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement, Touchscreen: шаг 26, изображение 2 из 2
    • Starting at the bottom right corner, insert the flat end of a spudger between the touchscreen and LCD frame and gently pry the touchscreen off the LCD.
    • Do not run the spudger down the side of the display assembly to loosen the touchscreen. The two components of the display assembly are held together by a fairly weak adhesive tape, and running the spudger between the two could tangle or damage the tape.
    • Insert the spudger into the top right corner between the two pieces and pry the touchscreen off the LCD frame.
  27. Nintendo 3DS Touchscreen Replacement: шаг 27, изображение 1 из 2 Nintendo 3DS Touchscreen Replacement: шаг 27, изображение 2 из 2
    • Repeat the above procedure for the remaining two corners to pry the touchscreen off the LCD frame.
  28. Nintendo 3DS Touchscreen Replacement: шаг 28, изображение 1 из 1
    • Gently lift the touchscreen up to completely separate it from the lower LCD.
Заключение
38 человек успешно провели ремонт по этому руководству.
David Hodson
Участник с: 04/13/10
152 623 Репутация
Автор 127 руководств
17 Комментариев
I had no problem with the screws. A while ago I invested in a multi bit precision screwdriver. If you are going to be taking apart electronics this is worth the $20-$30 investment in the long run. If you strip a screw then you have the wrong bit, stop what your doing and wait until you can get the right tool.
This guide could have at least some tips on putting the 3ds back together. It is a true test of your patience. I got mine back together with lots of swearing and having to remove the motherboard several times. It could have been mentioned to keep in eye on your volume and wifi switch position. because I got mine back together and the volume is stuck on full blast and the wifi switch is stuck on. I am going to wait to strip it down again because I have to replace a shoulder button soon anyway.
Also removing the frame on the touch screen was not mentioned and it is really easy to break because it is taped down onto the touch screen.
Overall an excellent guide. Thanks to the author!
Jody Jamieson - Ответить
we're having trouble trying to put the lcd board's small ribbon cable back into the motherboard. if anyone could help we would be very grateful. thank you
Green Brid - Ответить
all right, we got that, but now we're having trouble with redoing step 18--it's impossible to put the very short ribbon cable under the flap. any suggestions?
Green Brid -
Fantastic guide and pictures. Just finished replacing the touch screen in my daughter's 3DS. I had to take the unit apart again and re seat the top screen connector but otherwise no problems.
davesamwest - Ответить
Okay now does this fix the screen entirely because my friend can't use his screen anymore it is just black.
connornielsen02 - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 41
За последние 7 дней: 210
За последние 30 дней: 887
За всё время: 94,794
