Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the two Phillips screws securing the battery cover to the back of the handheld console.
Lift the battery cover off the back of the DSi XL.
Use a push pin to remove the four plastic screw covers on the front bezel.
Remove four Phillips screws securing the front bezel to the rear bezel.
Insert a spudger into the gap between the front and rear bezel
Rotate the spudger away from the DSi XL, prying the two bezels apart.
In the same manner as described above, continue prying along the top edge of the front and rear bezels.
Use the flat end of a spudger to pry the rear camera off the rear bezel.
Remove the rear bezel.
Use a spudger to lift the antenna from the front bezel to make room for lifting the speaker cables up.
Use a spudger to lift the right speaker from its housing in the front bezel.
Use a spudger to lift the left speaker from its housing in the front bezel.
De-route the left speaker cable along the top edge of the upper LCD.
Open the display slightly, and lift the LCD out of the front bezel.
Lay the LCD down next to the DSi XL.
Desolder the two solder joints to separate the speakers from the LCD.
Right Speaker
Left Speaker
3 участников успешно повторили данное руководство.
3 Комментариев
In my case, it turned out there was nothing wrong with my speaker… one of the wires that feeds around the screen was bad.
is there anyway of adding two more speaker?
