Введение
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Выберете то, что вам нужно
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the LCD ribbon cable ZIF connector.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair of tweezers to pull the ribbon cable straight out of its connector on the motherboard.
Use an opening tool, spudger, or your fingernail to flip up the small, hinged locking flap on the smaller LCD ribbon cable ZIF connector.
Heat an iOpener and apply it to the bottom edge of the screen for around two minutes to to help soften the adhesive.
Apply a suction cup to the bottom-left corner of the screen.
Pull up on the suction up with strong, steady force to create a gap.
Insert the point of an opening pick into the gap, making sure to only insert the pick about 5 mm.
Slide the opening pick along the bottom edge of the screen to slice the adhesive.
Leave the pick inserted to prevent the adhesive from re-adhering to the frame.
Insert a second opening pick into the gap to the left of the first pick.
Slide the opening pick back towards the left side of the device.
Leave the opening pick inserted.
Heat the left edge of the screen for around two minutes to help soften the adhesive.
Continue sliding the opening pick around the bottom-left corner to slice the adhesive.
Continue sliding the opening pick along the left edge of the screen to slice to adhesive.
Heat the top edge of the screen for around two minutes to help soften the adhesive.
Continue sliding the opening pick around the top-left corner of the screen to slice the adhesive.
Continue sliding the opening pick along the top edge of the screen to slice the adhesive.
Heat the right edge of the screen for around two minutes to help soften the adhesive.
Place the flat end of a spudger into the gap along the left edge of the screen.
Carefully and slowly lift the left edge of the screen, opening it like a book.
Lift the right edge of the screen straight off the device, threading the ribbon cables through the frame as you do so.
Heat the top edge of the screen assembly for around two minutes to help soften the adhesive holding the LCD panel to the digitizer.
Turn the screen assembly over.
Insert an opening pick in between the LCD panel and the digitizer at the top-left corner.
Slide the opening pick along the top edge of the screen assembly to slice the adhesive.
Heat the left edge of the screen assembly for around two minutes to help soften the adhesive.
Insert and slide the opening pick along the left edge of the screen assembly to slice the adhesive.
Continue sliding the opening pick around the bottom-left corner of the screen assembly to slice the adhesive.
Heat the bottom edge of the screen assembly for around two minutes to help soften the adhesive.
Heat the right edge of the screen assembly for around two minutes to help soften the adhesive.
Insert the flat end of a spudger in between the LCD panel and the digitizer along the left edge of the screen assembly.
Carefully and slowly lift up the left side of the LCD panel, opening it like a book.
Continue lifting the LCD panel away from the digitizer to separate the two components.
