Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide give instructions on how to locate the front LCD display for removal and/or repair.
Запчасти
Детали не указаны.
  1. Flip over the phone and then slide down the back cover with your thumb.
    • Flip over the phone and then slide down the back cover with your thumb.
  2. Lever out the battery from the phone using your thumb.
    • Lever out the battery from the phone using your thumb.
  3. With the phone closed, run a plastic opening tool along the seam of the top half of the phone. Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top). Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top).
    • With the phone closed, run a plastic opening tool along the seam of the top half of the phone.
    • Make sure to disconnect each of the five clips before proceeding (2 on each side, 1 on top).
  4. Using the T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel. Note that the fourth screw is under a fold in the ribbon cable.
    • Using the T6 Torx Screwdriver, remove the four 3.16mm screws from the front panel.
    • Note that the fourth screw is under a fold in the ribbon cable.
  5. Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down. Be careful around the two ribbon cables attached to the tape. These cables are fragile. Lift the tape from the board.
    • Starting in the lower right corner, slowly start to lift the tape that is holding the front LCD and cables down.
    • Be careful around the two ribbon cables attached to the tape. These cables are fragile.
    • Lift the tape from the board.
  6. Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
    • Using a plastic opening tool, lift the ribbon cable connection below the front LCD.
  7. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board. Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board.
    • Using a plastic opening tool, slowly pry up the LCD display from the bottom, releasing it from the glue holding it to the board.
Заключение
2 участников успешно повторили данное руководство.
Brett Balcer
Участник с: 04.10.2010
240 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-46, Amido Fall 2010 Участник Cal Poly, Team 4-46, Amido Fall 2010
CPSU-AMIDO-F10S4G46
4 членов
Автор 14 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 3
За последние 30 дней: 12
За всё время: 793
