Выберете то, что вам нужно
Press and hold the battery release button and slide the battery away from the Nokia logo
Insert a plastic opening tool between the faceplate and the black backplate. Gently pry them apart, working from the lower end to the upper side of the phone.
Remove the screw holding the antenna to the circuit board.
Carefully lift off the antenna from the circuit board.
Еще один человек закончил это руководство.
1 Комментарий к руководству
This includes removing the antenna, since it's just one screw.
The antenna guide talks about "replacing the antenna."
