Введение
Here is a Nokia Lumia 520 with a broken front glass. It is possible to purchase just the glass, but I opted against this. Nokia refers to the front assembly (Glass and Digitizer) as the Touch Window, it is around $10 and it is easy to replace. I previously tried unsuccessfully to separate the digitizer from the glass.
This guide is also applicable to the Nokia 521. The Nokia 521 has a 4th M1.5x3 screw in the lower left corner of the battery compartment, as shown in Step 3.
Инструменты
Запчасти
Детали не указаны.
The damage to the digitizer is clearly visible. Nokia refers to the glass/digitizer combo as the "touch window"
Turn the phone over,
and release the back cover by pushing it off the phone from the top
With the back cover removed, the battery becomes visible.
Lift up the battery from the bottom and remove it.
Unscrew the five Torx+4 screws.
These five screws are 5mm in length
Next remove the three Torx+4 screws
Those screws are machine screws M1.5x3
The Nokia 521 has a 4th screw in the lower left corner of the battery compartment.
Release the two clips on the bottom of the phone by using a guitar pick or similar opening tool
Simply insert the tool in the gap between the case halves and slightly rotate the tool to free the clips.
Continue to work the tool all the way round.
The last clip should be on the top of the phone.
Once those are released, the case will simply open up. With the cover (Nokia calls it the D-cover) removed, the logic board will be visible.
Remove the digitizer flex cable by using an opening tool, or spudger, from the connector
Here is the flex cable removed from the connector
Next remove the display flex with an opening tool, or spudger, from the connector.
Display flex removed from the connector
Use an opening tool, or a spudger, to remove the logic board from the case. It is simply held in by two clips.
Remove the logic board from the front assembly
Use a guitar pick or similar opening tool to unsnap the touch window assembly from the support frame.
This will separate the touch window from the rest of the phone.
101 участников успешно повторили данное руководство.
Комментариев: 20
I used a t5 screwdriver and it worked perfectly :D
tnx for the guide!!
Probably one of the easiest repairs i have ever done, tip pay, an extra few pounds and get the digitizer with the frame.
Hi Adrian, where did you buy the Touch Windows? I asked Nokia but they do not sell it..
Thanks.
Rod
The last and hardest step is missing---separating the digitizer from the surround. They are glued together and you basically have to destroy the glass to get it off. (See the teardown for details.) Other than that, a great guide, thanks.
Well... you're trying to replace the glass in the first place, so it's technically already destroyed.
Also, I broke my Lumia 520 screen and I'm waiting for the replacement screen to arrive. If you use your thumbnail or something very thin but strong, you can separate the glass from the frame without causing more damage to the glass by running it underneath the edges of the glass, all the way around.
Granted, it took a couple of goes to separate them because of the glue, but it did come off without breaking either the frame or the glass.
