Введение
This guide demonstrates how to replace the heating plate in a NuWave Brio 37001 air fryer.
The NuWave Brio 37001 comes equipped with a metal heating plate, which can be located at the bottom of the device. The device's cooking basket rests upon this component when inserted. This plate is responsible for transferring heat generated by the coil. If it is faulty, it can lead to slow or uneven cooking.
Be sure to leave the device unpowered while following this guide. Touching an active heating element can cause injury.
Make sure you visit the troubleshooting page before following this guide. There could be issues other than the heating plate that need fixing.
Выберете то, что вам нужно
Rest your appliance upside down, with the digital screen facing your work surface.
Remove the six 12 mm screws located around the edge of the bottom lid using a Phillips #1 screwdriver.
Remove four 10 mm screws using a Phillips #1 screwdriver.
Use your finger to flip up each small metal tab located around the heating plate.
2 участников успешно повторили данное руководство.
