OnePlus 7 Pro Screen Replacement
Выберете то, что вам нужно
Видео обзор
  1. OnePlus 7 Pro Screen Replacement, OnePlus 7 Pro Screen Replacement: шаг 1, изображение 1 из 3 OnePlus 7 Pro Screen Replacement, OnePlus 7 Pro Screen Replacement: шаг 1, изображение 2 из 3 OnePlus 7 Pro Screen Replacement, OnePlus 7 Pro Screen Replacement: шаг 1, изображение 3 из 3
    • Insert and gently push the SIM card ejector tool (or an unfolded paperclip) into the small hole on the left side of the top edge of the phone.
    • Press gently to eject the SIM tray.
    • Remove the SIM card tray from the device.
    • To reinsert the SIM card tray, orient the SIM card with the gold contacts facing up and the notch to the bottom right. Reinsert the SIM card by pressing the card gently into the SIM tray slot.
  2. OnePlus 7 Pro Screen Replacement: шаг 2, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 2, изображение 2 из 2
    • Use a heat gun to lightly heat the edges of the back to soften the adhesive that connects the back cover to the rest of the frame.
    • Using a heat gun, hair dryer, or hot plate will make the metal frame rather hot to the touch, so handle it with care.
    • Be careful not to overheat the device –the OLED display, battery and other internal parts can be damaged by excessive heat. Approximately one minute should be enough to soften the adhesive.
    • An iFixit iOpener, hairdryer, or hot plate can also be used to heat the edges. See the iOpener Heating guide for instructions on using the iOpener.
  3. OnePlus 7 Pro Screen Replacement: шаг 3, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 3, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 3, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    • Apply a suction cup to the lower portion of the phone's backing and pull firmly to create a crack between the back cover and the rest of the phone.
    • Insert a Jimmy tool, opening pick, or plastic card under the edge of the back cover.
  4. OnePlus 7 Pro Screen Replacement: шаг 4, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 4, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 4, изображение 3 из 3
    • Use a plastic card or Jimmy tool to slice around the phone's seam, cutting through the adhesive.
  5. OnePlus 7 Pro Screen Replacement: шаг 5, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 5, изображение 2 из 2
    • Remove the phone's back cover.
    • If you have replacement adhesive strips, remove any remaining adhesive from the device frame using the Jimmy tool.
  6. OnePlus 7 Pro Screen Replacement: шаг 6, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 6, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 6, изображение 3 из 3
    • Use a pair of tweezers to lift up the piece of black tape covering the laser autofocus and flash flex cable.
    • Use a pair of tweezers to lift and remove the covering on the laser autofocus and flash flex cable.
  7. OnePlus 7 Pro Screen Replacement: шаг 7, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the laser autofocus and flash flex cable.
  8. OnePlus 7 Pro Screen Replacement: шаг 8, изображение 1 из 1
    • Use a Phillips #000 screwdriver to remove the fourteen screws from the plastic motherboard cover.
  9. OnePlus 7 Pro Screen Replacement: шаг 9, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 9, изображение 2 из 2
    • Use the flat end of a spudger to lift up the plastic motherboard cover.
    • Remove the plastic motherboard cover.
  10. OnePlus 7 Pro Screen Replacement: шаг 10, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the power flex cable.
  11. OnePlus 7 Pro Screen Replacement: шаг 11, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 11, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 11, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the longer black coaxial cable.
    • Use the flat end of a spudger to disconnect the white coaxial cable.
    • Use the flat end of a spudger to disconnect the shorter black coaxial cable.
  12. OnePlus 7 Pro Screen Replacement: шаг 12, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 12, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 12, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the display and touch flex cable, main flex cable, and USB port cable.
  13. OnePlus 7 Pro Screen Replacement: шаг 13, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the black cable on the left-hand side of the phone.
  14. OnePlus 7 Pro Screen Replacement: шаг 14, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 14, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 14, изображение 3 из 3
    • Use the flat end of a spudger to pry up the long black cable on the left-hand side of the phone.
    • Use the flat end of a spudger to disconnect the end of the long black cable.
  15. OnePlus 7 Pro Screen Replacement: шаг 15, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 15, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 15, изображение 3 из 3
    • Use a pair of tweezers to pry up the red plastic tab.
    • Use a pair of tweezers to remove the assembly connected to the red plastic tab.
  16. OnePlus 7 Pro Screen Replacement: шаг 16, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the connector that was underneath the red plastic tab.
  17. OnePlus 7 Pro Screen Replacement: шаг 17, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 17, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove the remaining two screws securing the motherboard.
  18. OnePlus 7 Pro Screen Replacement: шаг 18, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 18, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 18, изображение 3 из 3
    • Use the flat end of a spudger to lift up the phone's motherboard.
    • Remove the motherboard.
  19. OnePlus 7 Pro Screen Replacement: шаг 19, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 19, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove two short screws.
    • Use a Phillips #000 screwdriver to remove one screw.
  20. OnePlus 7 Pro Screen Replacement: шаг 20, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 20, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 20, изображение 3 из 3
    • Use a pair of tweezers to remove the camera elevator assembly.
  21. OnePlus 7 Pro Screen Replacement: шаг 21, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 21, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 21, изображение 3 из 3
    • Lift up the large flex cable with your fingers.
    • Use a pair of tweezers to remove the black plastic screw covering.
  22. OnePlus 7 Pro Screen Replacement: шаг 22, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 22, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 22, изображение 3 из 3
    • Use a Phillips #000 screwdriver to remove two small screws from the metal covering.
    • Remove the metal covering.
  23. OnePlus 7 Pro Screen Replacement: шаг 23, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 23, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 23, изображение 3 из 3
    • Use the flat end of a spudger or your fingers to gently remove the front camera assembly.
  24. OnePlus 7 Pro Screen Replacement: шаг 24, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 24, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove one screw in the upper left-hand corner.
  25. OnePlus 7 Pro Screen Replacement: шаг 25, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 25, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 25, изображение 3 из 3
    • Use a pair of tweezers to disconnect the earpiece's yellow flex cable.
    • Use a pair of tweezers to remove the earpice.
  26. OnePlus 7 Pro Screen Replacement: шаг 26, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 26, изображение 2 из 2
    • Use your fingers to pull on the red sticker labelled 'Pull Up From This Side.'
    • Remove the battery.
  27. OnePlus 7 Pro Screen Replacement: шаг 27, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 27, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 27, изображение 3 из 3
    • Use your fingers to grab the black tab and remove the plastic that was underneath the battery.
  28. OnePlus 7 Pro Screen Replacement: шаг 28, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 28, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove eight screws from the bottom panel.
    • Use the flat end of a spudger to pry up the bottom cover.
    • Remove the bottom cover.
  29. OnePlus 7 Pro Screen Replacement: шаг 29, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the fingerprint sensor, the LED flex cable, the CED flex cable, and the display and touch flex cable.
    Can these flex cables be identified or labeled? I accidentally torn the one on the right with the metal plate covering vertically and need to identify it to order a part.
    Teewheezy - Ответить
  30. OnePlus 7 Pro Screen Replacement: шаг 30, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 30, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 30, изображение 3 из 3
    • Use the flat end of a spudger to disconnect the three coaxial cables near the bottom of the phone.
    • To disconnect the longer coaxial cable, you will need to pry the wire from its clips.
  31. OnePlus 7 Pro Screen Replacement: шаг 31, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 31, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 31, изображение 3 из 3
    • Use the flat end of a spudger to lift up the sub-board.
    • Remove the phone's sub-board.
  32. OnePlus 7 Pro Screen Replacement: шаг 32, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 32, изображение 2 из 2
    • Use a Phillips #000 screwdriver to remove two screws.
  33. OnePlus 7 Pro Screen Replacement: шаг 33, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 33, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 33, изображение 3 из 3
    • Use a pair of tweezers to peel out the black stickers from the sides and bottom of the battery area.
  34. OnePlus 7 Pro Screen Replacement: шаг 34, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 34, изображение 2 из 2
    • Use your fingers to remove the three signal cables.
  35. OnePlus 7 Pro Screen Replacement: шаг 35, изображение 1 из 1
    • Use the flat end of a spudger to disconnect the USB port flex cable.
  36. OnePlus 7 Pro Screen Replacement: шаг 36, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 36, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 36, изображение 3 из 3
    • Use your fingers to remove the LED flex cable, CED flex cable, and USB port cable.
  37. OnePlus 7 Pro Screen Replacement: шаг 37, изображение 1 из 2 OnePlus 7 Pro Screen Replacement: шаг 37, изображение 2 из 2
    • Use a pair of tweezers to disconnect the fingerprint sensor.
  38. OnePlus 7 Pro Screen Replacement: шаг 38, изображение 1 из 1
    • Remove the vibration sensor using a pair of tweezers.
  39. OnePlus 7 Pro Screen Replacement: шаг 39, изображение 1 из 1
    • Disconnect the coaxial cable in the lower left-hand corner using the flat end of a spudger.
  40. OnePlus 7 Pro Screen Replacement: шаг 40, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 40, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 40, изображение 3 из 3
    • Use a Phillips #000 screwdriver to remove two screws on the left-hand side of the phone's frame.
    • Use a pair of tweezers to remove the plastic piece that was secured with the two previous screws.
  41. OnePlus 7 Pro Screen Replacement: шаг 41, изображение 1 из 3 OnePlus 7 Pro Screen Replacement: шаг 41, изображение 2 из 3 OnePlus 7 Pro Screen Replacement: шаг 41, изображение 3 из 3
    • Remove the coaxial cable using the flat end of a spudger.
    • Remove the coaxial cable from the left-hand side of the battery's area.
Заключение
To reassemble your device, install each of the components removed during this guide into a new screen with a frame by following these instructions in reverse order.
8 человек успешно провели ремонт по этому руководству.
Selena
Участник с: 12/15/19
2 767 Репутация
Автор 14 руководств
12Комментарии к руководству
So I have a friend that owns this phone and has had the screen replaced, there is however some misalignment of the screen and frame on her phone in the form of a very obvious crack between the two, the two surfaces are also not flush. Could someone in theory have improperly repaired the phone by separating the screen from the frame and gluing a new one in place?
Thank you and have a nice day.
Clayton Lawliss - Ответить
No that is due to the frame being bent, if it is bent the screen will not sit properly and it is a difficult task to un bend a frame but it is possible.
Zach Benson -
Is it possible to replace just the top glass if the rest of the screen is intact? It's got surface cracks both front and back.
MJ Mulenga III - Ответить
No don't and I mean DONT go that route the glass or whatever seems cheaper but the repair of separating them is next to impossible. Its like trying to take a part two potatoe chips that have been glued together and in the process not breaking either. Get a screen replacement.
Zach Benson -
Absolutely none of this is necessary as they don’t sell the screen with the frame. If you’re unlucky like me you’ll get the entire phone apart and then it will tell you to reassemble parts onto screen WITH frame.
Joel Tool - Ответить
If there is ever an option when buying a screen saying with or without frame always get the frame. Its a little more spendy but saves so much hassle, anger and frustration. It's also one of those repairs people like myself dread!
Zach Benson -
Could this be used and adapted to replace the charging port?
S. S. - Ответить
Yes, I got the part on amazon and successfully replaced the charging port as well as the battery when I opened it
Daniel Malkowski -
In reviewing this, I was expecting more steps. It stops after #41 removing the coaxial cable. Nothing mentioned about the screen. Did something happen to the rest?
mesmurized - Ответить
Follow steps in reverse
Zach Benson -
After doing this now when I turned the phone back on for the first time and put in the pass code and first attempt it says I put the wrong password in 86 times and times out for like 900 seconds...
Zach Benson - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 9
За последние 7 дней: 86
За последние 30 дней: 453
За всё время: 19,761
