Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Replace the power fuse for the Onkyo TX800 receiver.
Выберете то, что вам нужно
Remove the two screws on both sides of the receiver. Keep these and the rest of the screws in a safe place.
Gently wedge a small screwdriver in between one side of the fuse and the contact.
Remove the fuse with your thumb and forefinger.
Examine the fuse. If the wire within it is broken, you will need to replace it with a new, 125 Volt, 4 Amp fuse.
5 участников успешно повторили данное руководство.
2 Комментариев
Thanks for clear instructions!
