Введение
This guide walks through the steps on how to remove the battery from the Orbo Jr so you can add a new battery.
Выберете то, что вам нужно
Use your thumbs to gently pry the silicon case away from the tablet starting at one of the corners. Once the first corner is separated the other three corners should slip off easily.
Use the plastic opening tool to pry the back off the tablet. Work your way around the edges. Once you have one side open you can slowly unsnap the rest of the case and use the tool as needed.
Gently pull the cables attached to the speaker to remove it from the back cover.
Use a nylon spudger to lift the battery from the right side of the device. Slowly remove the adhesive below the battery.
Desolder the battery wires from the positive and negative connection to the motherboard. Check out iFixit's How to Solder and Desolder Connections guide for soldering help.
Positive and Negative battery terminals.
