PDP Rematch Joystick Cover Replacement
Выберете то, что вам нужно
  1. PDP Rematch Joystick Cover Replacement, Faceplate: шаг 1, изображение 1 из 2 PDP Rematch Joystick Cover Replacement, Faceplate: шаг 1, изображение 2 из 2
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Joystick Cover Replacement: шаг 2, изображение 1 из 2 PDP Rematch Joystick Cover Replacement: шаг 2, изображение 2 из 2
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Joystick Cover Replacement: шаг 3, изображение 1 из 2 PDP Rematch Joystick Cover Replacement: шаг 3, изображение 2 из 2
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Joystick Cover Replacement, Joystick Cover: шаг 4, изображение 1 из 1
    • The action buttons and silicone pad are loose and may fall out of the controller.
  5. PDP Rematch Joystick Cover Replacement: шаг 5, изображение 1 из 2 PDP Rematch Joystick Cover Replacement: шаг 5, изображение 2 из 2
    • Gently rotate or twist the joystick(s) you want to replace.
    • Apply some force and pull upward towards you.
    • You will know it is released when you hear a popping sound.
    • Place your new joystick and push it downwards; you will hear a popping sound again.
Заключение
Еще один человек закончил это руководство.
Amina Begum
Участник с: 01/15/24
282 Репутация
Автор 2 руководств
Команда
Tennessee Tech University, Team 1-3, Pickering Spring 2024 Участник Tennessee Tech University, Team 1-3, Pickering Spring 2024
TNTECH-PICKERING-S24S1G3
4 членов
Автор 5 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 46
За всё время: 898
