PDP Victrix Pro BFG Battery and Trigger Replacement
Выберете то, что вам нужно
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: шаг 1, изображение 1 из 1
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
    Спросите у FixBot
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 2, изображение 1 из 1
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
    Спросите у FixBot
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 3, изображение 1 из 2 PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 3, изображение 2 из 2
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
    Спросите у FixBot
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 4, изображение 1 из 1
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
    Спросите у FixBot
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 5, изображение 1 из 1
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
    Спросите у FixBot
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 6, изображение 1 из 1
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
    Спросите у FixBot
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 7, изображение 1 из 1
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
    Спросите у FixBot
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 8, изображение 1 из 1
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
    Спросите у FixBot
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: шаг 9, изображение 1 из 1
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
    Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
ryanmorabito
Участник с: 03/20/24
260 Репутация
1 руководство автора
Команда
UMass Dartmouth, Team 1-1, Santin Spring 2024 Участник UMass Dartmouth, Team 1-1, Santin Spring 2024
UMASSD-SANTIN-S24S1G1
3 членов
Автор 4 руководств
5 Комментарии к руководству
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - Ответить Поделиться
R2 and L2 no response, the board location for button?
Terry - Ответить Поделиться
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - Ответить Поделиться
How much and how can I buy the battery's?
Dino - Ответить Поделиться
Really sucks that the L2 and R2 modules are all one big thing and not easily repairable. My R2 had a crack near the two screws and I went to Turtle Beach trying to get a replacement. They don't offer parts and I had to resort to superglue. I hope it holds up, but repairability for this controller is pretty low without access to the proprietary parts.
Michael Monn - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 46
За последние 30 дней: 219
За всё время: 6,557
