PSP 300x UMD Drive Replacement
Выберете то, что вам нужно
  1. PSP 300x UMD Drive Replacement, Battery: шаг 1, изображение 1 из 3 PSP 300x UMD Drive Replacement, Battery: шаг 1, изображение 2 из 3 PSP 300x UMD Drive Replacement, Battery: шаг 1, изображение 3 из 3
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x UMD Drive Replacement, Casing: шаг 2, изображение 1 из 1
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    This will end your warranty, so do it on your own risk!
    Paweł Kasztura - Ответить
    Even though warranties are long expired on these things.
    Vincent C. -
    “IF” your on this Site “I FIX IT(tm) to lean how to repair something on your own… you “Should NOT” be too concerned about warranty any longer, as if you were .. for your iPhone or Pad etc… you would have taken it to the supplier.. No??
    Barry Goian - Ответить
  3. PSP 300x UMD Drive Replacement: шаг 3, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 3, изображение 2 из 2
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x UMD Drive Replacement: шаг 4, изображение 1 из 1
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x UMD Drive Replacement: шаг 5, изображение 1 из 1
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    “DON’T” forget to put your screws separately on a mag mat (Or sticky tape) so to 1) Not loose them & 2) Remember where they go as they may be of differing sizes. (Refer time the pictures also helps, but you can take a pic on your camera as you go to remind you also.
  6. PSP 300x UMD Drive Replacement: шаг 6, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 6, изображение 2 из 2
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    J’ai récemment fait cette réparation et le boîtier avant ne voulait pas venir à condition d’enlever les deux vis sur le boîtier arrière au niveau du joystick et de la croix directionnelle. Il manque donc selon moi une partie mais je peux me tromper !
    Valentin Boileau - Ответить
  7. PSP 300x UMD Drive Replacement, LCD Screen: шаг 7, изображение 1 из 2 PSP 300x UMD Drive Replacement, LCD Screen: шаг 7, изображение 2 из 2
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    The homebar has a little tab screwed in place under the screw that alsoholds the lanyard trim-piece on. You will need to unscrew that screw first and pry the lanyard piece up, to get the homebar out from under it.
    B McG - Ответить
  8. PSP 300x UMD Drive Replacement: шаг 8, изображение 1 из 3 PSP 300x UMD Drive Replacement: шаг 8, изображение 2 из 3 PSP 300x UMD Drive Replacement: шаг 8, изображение 3 из 3
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    Attention à cette partie où l’écran est un peu bloqué dans le coin inférieur droit, il faut donner un peu de jeu vers la gauche pour le décaler et le retirer plus facilement.
  9. PSP 300x UMD Drive Replacement: шаг 9, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 9, изображение 2 из 2
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    For anyone struggling to get the screen’s smaller ribbon cable back in, don’t be too afraid to use tweezers to pull on the little tabs. It has to go in a good half way (of the darker area) in order for you to latch it without it falling back out.
    Tom - Ответить
  10. PSP 300x UMD Drive Replacement: шаг 10, изображение 1 из 1
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
  11. PSP 300x UMD Drive Replacement, Trigger Buttons: шаг 11, изображение 1 из 1
    • Remove the screw securing 'L' trigger to the PSP.
  12. PSP 300x UMD Drive Replacement: шаг 12, изображение 1 из 1
    • Remove the white plastic piece that holds the 'L' trigger in place.
  13. PSP 300x UMD Drive Replacement: шаг 13, изображение 1 из 1
    • Remove the 'L' trigger from the PSP.
  14. PSP 300x UMD Drive Replacement: шаг 14, изображение 1 из 1
    • Remove the screw securing the 'R' trigger.
  15. PSP 300x UMD Drive Replacement: шаг 15, изображение 1 из 1
    • Remove the white plastic piece that holds the 'R' trigger in place.
  16. PSP 300x UMD Drive Replacement: шаг 16, изображение 1 из 1
    • Remove the 'R' trigger from the PSP.
  17. PSP 300x UMD Drive Replacement, Analog Stick: шаг 17, изображение 1 из 1
    • Remove the screw from the bottom left edge of the PSP.
  18. PSP 300x UMD Drive Replacement: шаг 18, изображение 1 из 1
    • Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the the 'L' trigger off the PSP.
    Being careful not to break the ribbon cable, use the spudger to peel the adhesive button of the 'L' trigger off the PSP.
    buzinon - Ответить
  19. PSP 300x UMD Drive Replacement: шаг 19, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 19, изображение 2 из 2
    • Using a fingernail or spudger, flip up the retaining bracket on the d-pad and 'L' trigger ribbon cable.
    • Lift the black plastic bracket along with the d-pad contact pad, disconnecting the ribbon cable as you lift.
    Be careful - the memory card should be taken out by now. If not, the d-pad assembly will not come out. You can safely remove it if you forgot though.
    Kris - Ответить
  20. PSP 300x UMD Drive Replacement: шаг 20, изображение 1 из 1
    • Remove the cable from the connector and remove the entire black piece from the PSP.
  21. PSP 300x UMD Drive Replacement: шаг 21, изображение 1 из 1
    • Remove the screw holding the analog stick in place.
  22. PSP 300x UMD Drive Replacement: шаг 22, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 22, изображение 2 из 2
    • Flip up the lock on the analog sticks ribbon cable.
    • Remove the analog stick from the PSP.
  23. PSP 300x UMD Drive Replacement, Power Jack: шаг 23, изображение 1 из 1
    • Flip up the lock and detach the ribbon cable above the power jack.
  24. PSP 300x UMD Drive Replacement: шаг 24, изображение 1 из 1
    • Remove the screw from the power jack.
  25. PSP 300x UMD Drive Replacement: шаг 25, изображение 1 из 1
    • Carefully bend back the black tab holding the power jack in place and start pulling the jack up to release it from this clip.
    The plastic tab in this step is very fragile. Use care when bending the plastic tab back.
    Kris - Ответить
  26. PSP 300x UMD Drive Replacement: шаг 26, изображение 1 из 1
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
  27. PSP 300x UMD Drive Replacement, Speaker: шаг 27, изображение 1 из 2 PSP 300x UMD Drive Replacement, Speaker: шаг 27, изображение 2 из 2
    • Push the black tab at the bottom of the speaker to pop the speaker out of place, and remove the speaker.
    • The speaker is spring loaded, so be sure to keep an eye on it in case it starts doing flips into the air when you push the tab. Be careful not to lose or damage it!
    • Make sure the new/replacement speaker does not spring out during reassembly.
  28. PSP 300x UMD Drive Replacement, Motherboard: шаг 28, изображение 1 из 1
    • Remove the cable carefully by lifting upwards from port attached to the motherboard .
  29. PSP 300x UMD Drive Replacement: шаг 29, изображение 1 из 1
    • Flip up both of the locks and remove both cables as shown
  30. PSP 300x UMD Drive Replacement: шаг 30, изображение 1 из 1
    • Flip up the lock and remove the ribbon cable located at the bottom edge of the PSP.
  31. PSP 300x UMD Drive Replacement: шаг 31, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the bottom left screw attached to the PSP
  32. PSP 300x UMD Drive Replacement, Remove Power Switch Panel: шаг 32, изображение 1 из 3 PSP 300x UMD Drive Replacement, Remove Power Switch Panel: шаг 32, изображение 2 из 3 PSP 300x UMD Drive Replacement, Remove Power Switch Panel: шаг 32, изображение 3 из 3
    • Remove the screw located at the top of the power switch panel.
    • Gently lift and remove the panel from the switch side
  33. PSP 300x UMD Drive Replacement: шаг 33, изображение 1 из 1
    • Remove the silver rim on the right side of the PSP.
  34. PSP 300x UMD Drive Replacement: шаг 34, изображение 1 из 1
    • Remove the silver rim on the left side of the PSP.
  35. PSP 300x UMD Drive Replacement: шаг 35, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 35, изображение 2 из 2
    • Remove the motherboard from the PSP
  36. PSP 300x UMD Drive Replacement, UMD Drive: шаг 36, изображение 1 из 1
    • On the bottom of the back of the PSP, pull the white plastic piece out.
  37. PSP 300x UMD Drive Replacement: шаг 37, изображение 1 из 1
    • Use a spudger and pull the spring out and remove it from the PSP.
  38. PSP 300x UMD Drive Replacement: шаг 38, изображение 1 из 2 PSP 300x UMD Drive Replacement: шаг 38, изображение 2 из 2
    • Open the UMD (disk drive) and locate the two small black rubber squares wedged in the space between the casing and the metal drive hinge on either side.
    • Pull these out using a pair of tweezers.
  39. PSP 300x UMD Drive Replacement: шаг 39, изображение 1 из 1
    • Detach the metal piece from where it is attached to the body underneath the rubber pieces that were just removed.
    • The side of the piece that is closest to the door opening should now be loose. The whole piece should now be slid farther into the drive through the slots.
    • Once you slide the piece toward the back of the slots, the side that is still attached can be pried towards the center of the drive on each side to remove it from the slots on the door.
  40. PSP 300x UMD Drive Replacement: шаг 40, изображение 1 из 1
    • Grabbing the PSP with both hands, gently pinch the UMD lid towards the right side (the side without the battery).
    • Pull up and the the left side carefully to remove the lid from the PSP. (The casing may have to flex a little bit to allow this)
  41. PSP 300x UMD Drive Replacement: шаг 41, изображение 1 из 1
    • Remove the four screw from the UMD drive.
  42. PSP 300x UMD Drive Replacement: шаг 42, изображение 1 из 1
    • Remove the UMD Drive.
Заключение
22 участников успешно повторили данное руководство.
mbnewsom
Участник с: 10/28/09
3 103 Репутация
Автор 11 руководств
6 Комментариев
Perfect!!! You forgot to mention 'GET YOUR EYEGLASSES' for the 50+ year old fathers that have to help on this procedure!!!! Man, oh man, are those parts small and delicate!!!! GREAT tutorial, than you very much! Blind in Boston.
Rosebud Mosaics - Ответить
The tutorial was great btw, however after assembling everything into my new blue Mod i was left with a white plastic piece and a spring witch is in my psp 3001 models , not sure but i see in the last picture of this tutorial you have the white piece left in the drive. it is located behind the cd rom part near the top of the psp where the 2 x holes are. it sucks cause it dont close properly without the white piece and theres also 1 of the 2 springs not mentioned in this tutorial neither im trying to figure out where it goes. But thanks for this guide as it has helped me alot..
Ken
Kenneth A - Ответить
Someone found the location of the missing spring? Haven’t figured it out yet…
tanja-stephan -
This has too many extra steps. If you’re *just* taking out the UMD drive, you only need to follow these sections: battery, casing, LCD screen, UMD drive. This guide should really just be called “how to completely disassemble your PSP 3000”.
Christopher Dickinson - Ответить
What about removing the UMD trigger? I didn’t see it anywhere in this tutorial. Please help.
C Rad - Ответить
wszystko zgodnie z instrucją , i drugi ekran wylany mimo ostroznosci, autor zapomnial dodac ze od razu ekran mozna sobie nowy zamawiac bo wg tego gownianego opisu uszkodzicie sobie lcd i nie gowno nie ostroznosc wam pomoze autorowi zycze aby ci huju kazdy sprzet sie w rekach rozwalal
Kamil Dobrzeniecki - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 34
За последние 7 дней: 198
За последние 30 дней: 743
За всё время: 45,118
