Pacific Image Electronics CS3600 Bulb Panel Replacement
Выберете то, что вам нужно
  1. Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: шаг 1, изображение 1 из 2 Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: шаг 1, изображение 2 из 2
    • Start by removing the 5 screws that are 5mm x 9mm located on the bottom of the device with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 2, изображение 1 из 1
    • Now that the screws have been removed, carefully but firmly open up the device at the seam until it is presented as shown.
  3. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 3, изображение 1 из 1
    • Use a J0 screwdriver to remove the following four screws that are 5mm x 9mm.
  4. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 4, изображение 1 из 1
    • Use the same J0 screwdriver to remove the following 3 screws that are 7mm x 6mm.
  5. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 5, изображение 1 из 1
    • Now grab the plastic cover you just removed screws from and gently remove it from the device.
  6. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 6, изображение 1 из 1
    • You may now pick up the plastic covering you removed screws from in Step 3 with ease revealing the bulb.
  7. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 7, изображение 1 из 1
    • Lodge the plastic opening tool underneath the bulb casing. Using some upward force, pop the bulb off the casing.
  8. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 8, изображение 1 из 1
    • You have now removed the bulb from the casing. Gently pull the wires forward and prepare a soldering station.
  9. Pacific Image Electronics CS3600 Bulb Panel Replacement: шаг 9, изображение 1 из 1
    • Carefully desolder the 2 wires from their solder contact points to detach the bulb panel from the motherboard.
Заключение
Еще один человек закончил это руководство.
Kristen Prince
Участник с: 03/21/17
201 Репутация
Автор 2 руководств
Команда
Texas Tech, Team S46-G2, Bennett Spring 2017 Участник Texas Tech, Team S46-G2, Bennett Spring 2017
TTU-BENNETT-S17S46G2
3 членов
Автор 10 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 0
За последние 30 дней: 1
За всё время: 417
