Panasonic Lumix DMC-F7 Front Case Replacement
Выберете то, что вам нужно
  1. Panasonic Lumix DMC-F7 Front Case Replacement, Battery: шаг 1, изображение 1 из 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 2, изображение 1 из 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Front Case Replacement, Back Case: шаг 3, изображение 1 из 1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 4, изображение 1 из 1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 5, изображение 1 из 1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 6, изображение 1 из 2 Panasonic Lumix DMC-F7 Front Case Replacement: шаг 6, изображение 2 из 2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 7, изображение 1 из 2 Panasonic Lumix DMC-F7 Front Case Replacement: шаг 7, изображение 2 из 2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 8, изображение 1 из 1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
  9. Panasonic Lumix DMC-F7 Front Case Replacement, Front Case: шаг 9, изображение 1 из 1
    • Remove the last two 2.8 mm Phillips #00 screws from the bottom of the camera.
  10. Panasonic Lumix DMC-F7 Front Case Replacement: шаг 10, изображение 1 из 3 Panasonic Lumix DMC-F7 Front Case Replacement: шаг 10, изображение 2 из 3 Panasonic Lumix DMC-F7 Front Case Replacement: шаг 10, изображение 3 из 3
    • Using the spudger, pry the front case away from the camera's components.
    • Use your fingers to carefully pull the back case from the front case.
    • Cut the black and red wires connecting front case to the body of the camera.
    • Be careful to ensure that internal materials won't be caught.
    • Separate the front of the case from the camera.
    • To reinstall the front case, solder the wires of the new case to the components of the camera.
Заключение
Еще один человек закончил это руководство.
Alex Penman
Участник с: 01/28/11
463 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 7-35, Regan Winter 2011 Участник Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 12
За последние 30 дней: 15
За всё время: 820
