Введение
Would you like to switch out the watch band on your Pebble Steel from leather to metal or vice versa? This guide will show you how.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Flathead 1.5 mm Screwdriver$5.49
Place the watch on its side to expose the side pins.
Use a 1.5 mm flathead screwdriver to unscrew the pin that is holding the band.
Turn the watch to the other side and repeat steps 1 and 2 to remove the other band.
3 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
One of my Pebble Steel pins comes out just as expected, but the other just spins, and doesn’t come out. Any ideas?
