Pentax Super Program Front Block Functional Check
  1. Pentax Super Program Front Block Functional Check, Prepare the front block: шаг 1, изображение 1 из 3 Pentax Super Program Front Block Functional Check, Prepare the front block: шаг 1, изображение 2 из 3 Pentax Super Program Front Block Functional Check, Prepare the front block: шаг 1, изображение 3 из 3
    • Connect a lead wire to the main flex PCB to supply battery power (early production).
    • Connect a lead wire to the main flex PCB to supply battery power (late production).
    • Make a ground connection to the body of the camera.
    Спросите у FixBot
    Добавить комментарий
  2. Pentax Super Program Front Block Functional Check, Prepare the mode dial: шаг 2, изображение 1 из 2 Pentax Super Program Front Block Functional Check, Prepare the mode dial: шаг 2, изображение 2 из 2
    • Ground the mode dial plate to the chassis of the front block.
    • Move the mode dial to the 'M' position.
    • Be careful not to let the ball bearing escape when passing through 'Auto' mode (the larger hole).
    Спросите у FixBot
  3. Pentax Super Program Front Block Functional Check, Check power to the front block: шаг 3, изображение 1 из 2 Pentax Super Program Front Block Functional Check, Check power to the front block: шаг 3, изображение 2 из 2
    • Use a source of 2.8 V to power the front block, the lowest battery voltage that the camera should operate at.
    • If an external power supply is not available, use fresh batteries to supply power.
    • Check the voltage at these locations to make sure that power is getting to all of the components.
    Спросите у FixBot
  4. Pentax Super Program Front Block Functional Check, Check the main shutter release: шаг 4, изображение 1 из 3 Pentax Super Program Front Block Functional Check, Check the main shutter release: шаг 4, изображение 2 из 3 Pentax Super Program Front Block Functional Check, Check the main shutter release: шаг 4, изображение 3 из 3
    • Charge the mirror mechanism.
    • Press the shutter button. The mirror should release and flip up into the taking position.
    • Push the mirror return latch to flip the mirror down into the viewing position (the shutter would trigger this mechanism when the camera is fully assembled).
    Спросите у FixBot
  5. Pentax Super Program Front Block Functional Check, Check the self-timer: шаг 5, изображение 1 из 2 Pentax Super Program Front Block Functional Check, Check the self-timer: шаг 5, изображение 2 из 2
    • Pull out the tab on the self-timer switch.
    • Press the shutter release button.
    • The self-timer led should blink and the buzzer should sound.
    • After ten seconds, the mirror should flip up.
    Спросите у FixBot
  6. Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: шаг 6, изображение 1 из 2 Pentax Super Program Front Block Functional Check, Check the motor drive shutter release: шаг 6, изображение 2 из 2
    • Ground this pad to release the shutter (early production).
    • Ground this pad to release the shutter (late production).
    • This is the signal that the accessory motor drive uses to fire the shutter. It's also a useful alternative if you think there is an issue with the main shutter release.
    Спросите у FixBot
    • Mount a lens on the front block. Set the aperture ring to 'A'.
    • Point the front block at scenes with varying brightness. Check that the aperture value in the viewfinder display changes accordingly.
    Спросите у FixBot
  7. Pentax Super Program Front Block Functional Check, Check viewfinder backlight: шаг 8, изображение 1 из 2 Pentax Super Program Front Block Functional Check, Check viewfinder backlight: шаг 8, изображение 2 из 2
    • Cover the ambient light panel for the viewfinder displays.
    • Press viewfinder light button on the side of the lens mount.
    • The displays at the bottom of the viewfinder should light up.
    Спросите у FixBot
Заключение
Sam Gustafson
Участник с: 09/01/22
11 000 Репутация
Автор 75 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 41
За всё время: 98
