Введение
The suppression capacitor in the Senseo Quadrante unfortunately often breaks down. The machine then no longer starts or the pump fails. The exchange is quite simple. You need a 0.47uF capacitor, class X2, at least 275 V, 22 mm pitch, which is easily available at any electronics store.
The repair goes quite similar to other devices
Выберете то, что вам нужно
Remove all attachments such as cup rack, pod holder and water tank.
The side panel must first be detached at the bottom edge. Turn the machine so that the bottom is facing towards you.
There are two indentations on the base plate with catches inside each one. Press in the catches with a screwdriver and detach the side panel at the bottom edge.
Chances are the plate will get stuck. It is recommended that you use a plastic pry tool to avoid scratching.
Work through the steps in reverse order to reassemble your device.
2 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
100%
shingleпомогает нам починить мир! Хотите внести свой вклад?
Начните переводить ›
2 Комментариев
Let op de + en - aansluiting van de condensator!
Dit type condensator heeft geen polariteit. Heb je de verkeerde condensator geïnstalleerd?
VauWeh -
