Введение
This guide is for the Philips Sonicare 2 series HX6211/46 toothbrush. It shows you how to replace the motor for this toothbrush. He is a link for a guide how to soldering which will be needed for this guide. How To Solder and Desolder Connections
Выберете то, что вам нужно
Pull upwards to remove the brush head from the top of the device.
Remove the 12 mm T8 Torx screw from the bottom of the toothbrush. After removing the screw, pry off the base with a plastic opening tool.
Remove the internal electronic mechanism from the housing by prying the red clips shown in the figure. This removes the charging port.
Next you will be able to remove the internal electronic mechanism as shown in the figure.
Remove the white circuit board cover as shown. This cover will require you to pry off the piece from the groves .
Disassemble the device. Remove the plastic piece over the brush attachment as shown. Object can be removed by hand as shown. No tool is required.
