Philips Sonicare FlexCare Battery Replacement
Выберете то, что вам нужно
  1. Philips Sonicare FlexCare Battery Replacement, Battery: шаг 1, изображение 1 из 1
    • Pull the brush head away from the handle to remove it.
  2. Philips Sonicare FlexCare Battery Replacement: шаг 2, изображение 1 из 1
    • Push the flat edge of a metal or nylon spudger between the seal and the toothbrush body and pry it open. Do this all around the edge until the seal is partially sticking out.
    • Have a look to an alternative opening procedure.
  3. Philips Sonicare FlexCare Battery Replacement: шаг 3, изображение 1 из 1
    • Apply pressure to the shaft by pressing it against a firm and flat surface. Continue to apply pressure until the electronics located in the interior are exposed.
  4. Philips Sonicare FlexCare Battery Replacement: шаг 4, изображение 1 из 1
    • Grab the circular, plastic base with the o-ring and pull it outward.
  5. Philips Sonicare FlexCare Battery Replacement: шаг 5, изображение 1 из 1
    • Remove the cap that is attached to the end of the interior by removing the two clasps that are holding it in place.
  6. Philips Sonicare FlexCare Battery Replacement: шаг 6, изображение 1 из 1
    • Desolder the battery from the circuit board. Here is a guide on how to desolder. Remove the old battery and replace it. Using the same guide, solder the battery in place.
    • The soldering points are shown in red.
Заключение
36 участников успешно повторили данное руководство.
Joanna Moraza
Участник с: 04/14/15
1 509 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 4-6, Maness Spring 2015 Участник Cal Poly, Team 4-6, Maness Spring 2015
CPSU-MANESS-S15S4G6
4 членов
Автор 23 руководств
36 Комментариев
has anyone ever done this successfully? OMG it seems daunting!!!!
Jo - Ответить
I'm going to try it. Now, to find a battery source.
Scott Minton - Ответить
Anyone knows where to purchase such battery and its type/sort code?
Ben Salem - Ответить
The battery is a 14500 li-ion with soldered pins.
I bought this one without pin and will try to solder them:
http://www.ebay.de/itm/371716530024
Here, you can buy the version with pins:
https://www.amazon.com/Battery-Sonicare-...
mamuc -
Prying open the bottom of the brush like that can damage the plastic. There's a damage-free technique detailed on this guide:
http://toothbrushbattery.com/guides/phil...
Dave W - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 125
За последние 7 дней: 850
За последние 30 дней: 3,689
За всё время: 272,669
