Введение
This guide will be helpful in the case that your device will not charge or has been dislodged. In this guide you will be using a #1 and #1.5 screwdriver, to remove screws and components. Once you have access to the motherboard, locate and use soldering techniques to remove USB connector.
Выберете то, что вам нужно
Unscrew all twelve Hex Head 1.5 (Length-3/8", Head- 1/8") screws using a 1.5mm hex screwdriver.
Remove the rubber casing by using your fingers to pull off. Be sure not tear or rip rubber casing.
Flip the device upside down and remove all eight Phillips (Length-3/8", Head-1/8") Screws using a standard #1 Phillips screwdriver.
Use plastic opening tool to pry off back plate.
Move the plastic opening tool along the the device to further pry open the device.
Identify the two Phillips (Length-5/16", Head-1/8") screws holding the battery in place and remove them using a #1 screwdriver.
Remove the ICR18650-26M battery from its position by pulling upwards and out of the casing.
Identify the motherboard and three Phillips (Length-1/8", Head-1/8") screws and remove them using a #1 screwdriver.
Identify the USB connector. Remove and replace the component with a functioning USB device. Refer to the link below for soldering techniques. How To Solder and Desolder Connections
3 Комментариев
Any way to buy the entire motherboard? Any suggestion where can I buy it?
Where can I purchase the usb
Where can I purchase the usb. There are so meany I don't know how to tell the correct one. Thank
