Photive Rain Motherboard Replacement
Выберете то, что вам нужно
  1. Photive Rain Motherboard Replacement, Back Panel: шаг 1, изображение 1 из 1
    • Turn the speaker off before disassembling.
    • Remove the suction cup from its groove by twisting and turning it.
  2. Photive Rain Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the four 8.5 mm screws from the back panel of the speaker by using the Phillips #1 Screwdriver.
    • Remove back panel
  3. Photive Rain Motherboard Replacement, Battery: шаг 3, изображение 1 из 2 Photive Rain Motherboard Replacement, Battery: шаг 3, изображение 2 из 2
    • Remove the plastic cover in front of the battery slot.
    • Unscrew all the 8.5mm screws that hold the cover to the slot.
    • Separate the battery from the back panel as shown in photograph 3.
    • Caution: manipulation of the device while the battery is still connected to the motherboard may result in electric shock.
  4. Photive Rain Motherboard Replacement: шаг 4, изображение 1 из 1
    • Remove the battery from the motherboard.
    • Use a soldering pen to remove the solder connecting the battery wires to the motherboard.
    • Click here to access the iFixit Soldering Guide. This will provide a safe and instructive manual on the usage of soldering pens.
  5. Photive Rain Motherboard Replacement, Speaker: шаг 5, изображение 1 из 1
    • Carefully remove the front panel from the device.
  6. Photive Rain Motherboard Replacement: шаг 6, изображение 1 из 1
    • Detach the connector clips from the motherboard using the iFixit Opening Tool.
    • Some force may be necessary to remove the plastic clips.
  7. Photive Rain Motherboard Replacement: шаг 7, изображение 1 из 2 Photive Rain Motherboard Replacement: шаг 7, изображение 2 из 2
    • After the speaker is detached, remove the two 8.5mm screws that hold the speaker to the front panel with a Phillips #1 screwdriver.
  8. Photive Rain Motherboard Replacement, Motherboard: шаг 8, изображение 1 из 1
    • From the back of the motherboard, unscrew the three phillips head screws holding the motherboard in place.
  9. Photive Rain Motherboard Replacement: шаг 9, изображение 1 из 1
    • Pull the rubber away from the edge of the motherboard.
  10. Photive Rain Motherboard Replacement: шаг 10, изображение 1 из 2 Photive Rain Motherboard Replacement: шаг 10, изображение 2 из 2
    • Use the plastic opening tool to remove motherboard from device.
    • The second photograph displays a properly removed motherboard.
Заключение
3 участников успешно повторили данное руководство.
abcdef ghijk
Участник с: 02/15/16
723 Репутация
Автор 4 руководств
Команда
IUPUI, Team 1-4, Harley Spring 2016 Участник IUPUI, Team 1-4, Harley Spring 2016
IUPUI-HARLEY-S16S1G4
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 8
За всё время: 293
