Выберете то, что вам нужно
Open the console case and remove the disk driver.
Be careful with the flat cables and its connectors.
Remove the disk tray and remove the gear plastic conver protection.
You dont need to remove any gear form its place.
Remove the old belt and replace with a new one.
The belt must be a PS2 fat compatible belt. If you don't have a PS2 you can use a radio K7 driver belt but it need to have the same diameter of the PS2 belt.
Old and lax belt.
Brand new belt.
Don't loose the opportunity and clean the laser lens with a cotton swab.
5 человек успешно провели ремонт по этому руководству.
