PlayStation 4 Pro Fan Replacement
Выберете то, что вам нужно
  1. PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: шаг 1, изображение 1 из 3 PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: шаг 1, изображение 2 из 3 PlayStation 4 Pro Fan Replacement, Hard Drive Caddy: шаг 1, изображение 3 из 3
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
    DON’T FORGET TO HAVE THERMAL PASTE HANDY! It should be added to the “Tools Required” Section. You will NEED it!
    Jaquell Chandler - Ответить
    What if thermal paste is not applied again when remounting ? Will the playstation start and work anyway or not ?
    Vincent Bee - Ответить
    It will start and run normally until you put it under load. Then it will heat up and thermal throttle or it can overheat and destroy itself.
    Jeremy Ivey -
    I posted this down in another step too, but: if you have a very early North American PS4 Pro, with the exact optical drive shown here - the key way to tell is the very long data cable that’s folded a couple of times, see pictures in later steps - then the replacement drive iFixit offers WILL NOT WORK IN YOUR MACHINE. It has to be a very early model, apparently, but the model number isn’t enough to tell you.
    Even if you swap the too-short cables in their replacement with the longer cables on your drive, it still will not work. At all. It’ll just sit there like the drive isn’t even getting power.
    So if you do have this drive, what you probably need to do is get a replacement KES-496A Optical Pickup Assembly and replace that within your existing drive. That’s what I had to do after two different replacement drives sent by iFixit failed to work in my system. It worked immediately and I’m back online.
    The optical pickup replacement is awfully fiddly, and adds a solid 20 minutes to the repair easily. But it does work.
    Dara Korra'ti - Ответить
    I had originally been told by several people that to properly repair the optical drive within the PS4 Pro (so that the PS4 actually works), you have to replace the Optical Pickup Assembly like you mentioned because the drive is paired with the motherboard. I was surprised to find that iFixit is pushing this repair tutorial when it has a low probability of success for many PS4 Pro models.
    Instead, iFixit should be documenting replacement of the KES-496A Optical Pickup Assembly... when that repair has a near 100% chance of success, even though it's a fair bit more fiddly to complete and requires two different teardowns (one for the PS4 Pro and one for the optical drive... needed to install the replacement optical pickup assembly).
    commorancy -
    Follow-on note. I could be mixing up the original PS4's pairing with the PS4 Pro (which might or might not have device + motherboard pairing). Because I can't find a definitive source confirming if the drive is paired on the PS4 Pro, using a drive replacement might or might not work.
    There are a number of commenters below who followed these instructions and found that the replacement drive didn't work after completing the repair. I think I'd still go with replacing the KES-496A Optical Pickup Assembly. That repair is more fiddly, but the optical assembly replacement part is a whole lot cheaper, costing less than $10 in some stores, than buying a full replacement drive at $70.
    commorancy -
  2. PlayStation 4 Pro Fan Replacement: шаг 2, изображение 1 из 2 PlayStation 4 Pro Fan Replacement: шаг 2, изображение 2 из 2
    • Use a Phillips #1 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
    This is a Phillips #1 bit.
    Trevor Frey - Ответить
  3. PlayStation 4 Pro Fan Replacement, Power Supply Assembly: шаг 3, изображение 1 из 3 PlayStation 4 Pro Fan Replacement, Power Supply Assembly: шаг 3, изображение 2 из 3 PlayStation 4 Pro Fan Replacement, Power Supply Assembly: шаг 3, изображение 3 из 3
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
    %#*@. I thought I was gonna break the thing. You really do have to give it some elbow grease.
    Addison Francisco - Ответить
    there were also some screws that needed to come out before popping it off. Might have been a different version im working on. there were three screws attached to the console that I had to remove before popping off the top.
    Ricky Arias - Ответить
    The 7215B has one TR8 security Torx behind the center “void” sticker.
    cylentstorm - Ответить
    This cover is really on there. It sounds like your breaking plastic when you pop it open. I ended up using a metal tablespoon in the corners where you should pull up to pop the cover up the first bit, worked well.
    azade91 - Ответить
  4. PlayStation 4 Pro Fan Replacement: шаг 4, изображение 1 из 3 PlayStation 4 Pro Fan Replacement: шаг 4, изображение 2 из 3 PlayStation 4 Pro Fan Replacement: шаг 4, изображение 3 из 3
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
    I copy the comment written by Jason at the end of this guide, because it’s better to have it here:
    This guide is for the initial release CUH-7000 models. Of note is the changes to the CUH-7100 series that do make this guide an issue. Steps 4 and 5 have a different items to note. You can damage it following this guide if you don’t adjust. There no longer 3 security screws for the case, but just one. This single screw is still covered by a warranty sticker, but the second one is a blank sticker and no screw behind it. There is also no 10mm screw in the center power supply in Step 4, it’s a support post. You still remove the 4 other screws, but you must then flip the console over and remove a T8 screw to the right on the HDD cage and another closer to the right side. You can then flip the console over again to remove the battery and plug it. Just remove all the metal plate screws to be sure, but make sure you hold the board when you flip it again or you will bend the battery prongs like I found out the hard way.
    kautame - Ответить
    Oh! That explains why I stripped the middle screw. What’s a support post?
    Philippe Morin -
    Had to use TR8 instead of 10mm here.
    After I popped the top off, I got 4 out of 5 screws out. The 5 th screw for some reason, was a little bit bigger, therefore, I could not take out that screw so I could clean the heatsink and fan.
    Dixie Dawg - Ответить
    Me too it’s not like another screw it’s have black and I can’t remove if you know pls tell me how i do bro ???
    Montri Meka -
    I stripped the %#*@ screw in the middle. (orange highlighting) It’s a black head and the T8 Torx Security head doesn’t work! I have a CUH-7115B. I think it’s a regular T8 or some kind of Hex head. ? I don’t know what to do now!! :(
    Philippe Morin - Ответить
    As mentioned above, this guide is for the old models. 7215B: There 4 TR8 screws (2 long, 2 short) holding the plate. The middle is a support post.
  5. PlayStation 4 Pro Fan Replacement: шаг 5, изображение 1 из 3 PlayStation 4 Pro Fan Replacement: шаг 5, изображение 2 из 3 PlayStation 4 Pro Fan Replacement: шаг 5, изображение 3 из 3
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
    Adding to this, the screws are not visible unless you remove the warranty stickers!
    George Diaz - Ответить
    Also, the plastic on the back of the cover is prone to cracking. Be careful and undo snaps across the whole back of the panel gently!
    Nick Podrebarac - Ответить
    Vielen vielen Dank. Endlich ist der jumbojet gelandet #fan
    Christian Radke - Ответить
    7215B has 1 TR8 screw beneath a sticker between the optical and USB ports, and two clips (1 next to the HDD slot and 1 beneath a sticker near the power port.)
  6. PlayStation 4 Pro Fan Replacement: шаг 6, изображение 1 из 3 PlayStation 4 Pro Fan Replacement: шаг 6, изображение 2 из 3 PlayStation 4 Pro Fan Replacement: шаг 6, изображение 3 из 3
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • 7200-series models have 13 additional 4mm screws around the top and right of the metal plate. These screws are are indicated with a triangle. This may apply to other models.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
    Noted during my replacement that the PS4 Pro appears to have additional #0 Phillips Head screws in Step 6 required to remove the metal plate from the motherboard and that the metal “X” plate in Step 11 appears to be included now in this overall metal cover for the motherboard, no longer separate, which accounts for the additional screws.
    David Carlsen - Ответить
    Original pro here. Had 12 torx
    Skyler Cook - Ответить
    cuh0-7216b have more philips #1 screws on metal plate on right, +13 screws :)
    Papolo0 - Ответить
    (PS4 Pro) Bei mir ebenfalls 11 T8 Torx, von denen 3 Sicherheitstorx waren.
    Rebecca Dorsch - Ответить
    My PS4 Pro 7115 has additional sets of #0 Phillips screws on the plate. 10x in the primary processor space (blank plate area of the graphic here), 2x over the fan, and 1x on the outside edge to clamp down on the primary processor area. Model CUH-7115B
    r0flm4k3r - Ответить
    What are the 3 different antennas identifications or functionality ?
    Robert Aldred - Ответить
  7. PlayStation 4 Pro Fan Replacement: шаг 7, изображение 1 из 2 PlayStation 4 Pro Fan Replacement: шаг 7, изображение 2 из 2
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. PlayStation 4 Pro Fan Replacement: шаг 8, изображение 1 из 2 PlayStation 4 Pro Fan Replacement: шаг 8, изображение 2 из 2
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
    What the cable in the up left corner is for? I broke it and i’d like to know at what is it connected?
    Thanks
    Enrico Pensalfine - Ответить
    The blue ribbon cables aren’t connected to the metal plate. The plate can be safely removed beforehand. The only thing one should do prior to its removal is de route the antenna cables for the WNIC.
    Robert - Ответить
  9. PlayStation 4 Pro Fan Replacement: шаг 9, изображение 1 из 1
    • Pull up and remove the metal plate.
  10. PlayStation 4 Pro Fan Replacement: шаг 10, изображение 1 из 3 PlayStation 4 Pro Fan Replacement: шаг 10, изображение 2 из 3 PlayStation 4 Pro Fan Replacement: шаг 10, изображение 3 из 3
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
    Why do I have to remove the PSU here? I do not see the necessity judging by the following steps.
    Alexander Bla - Ответить
    This comes in handy when removing the entire motherboard which is necessary when cleaning the heat sink.
    George Diaz -
    Bonjour, Que se soit le connecteur du bloc comme celui sur la partie ps4 , il est difficile à retirer ce câblage… peut-on tirer sans risque réellement ?
    Brezu Sama - Ответить
    IMPORTANT: The connector on the motherboard is very sensitive. I’d recommend using pliers to put pressure down on the connector while slowly jerking the cable out of the socket to avoid serious damage to the connector and/or motherboard that could render the PSU connection useless and require advanced soldering / rewiring.
    Daniel Larusso - Ответить
    This!
    Connector was quite tight in PSU side and I ended pulling connector from motherboard resulting me getting PS5 for Christmas.
    tero -
    Also der stecke lässt sich nicht entfernen
    Slime - Ответить
    Der Stecker am Netzteil (letzter Schritt) erscheint mir ungewöhnlich fest, und lässt sich ohne weiteres nicht entfernen. Besteht die Möglichkeit, dass dieser neuerdings verklebt ist oder dergleichen? :-/
    Das würde mich auch interessieren. Ich habe den Stecker weder vom Mainboartd noch von der PSU abbekommen. Leider habe ich den Stecker dann abgerissen - aber er hat sich auf keiner Seite abziehen lassen.
    Tobias August -
    Bei dieser Stecker-Buchse Verbindung handelt es sich um einen Molex-Stecker, der verriegelt ist. An der Seite befindet sie ein kleiner Hebel, den man nach innen drücken muss, damit sich der Stecker löst.
    Volker Diederichs - Ответить
    Danke für die Info!
    Fabian Neidhardt -
  11. PlayStation 4 Pro Fan Replacement, Motherboard: шаг 11, изображение 1 из 3 PlayStation 4 Pro Fan Replacement, Motherboard: шаг 11, изображение 2 из 3 PlayStation 4 Pro Fan Replacement, Motherboard: шаг 11, изображение 3 из 3
    • If you are working on the 7200-series model, this metal plate will have been already removed as part of the removing the larger motherboard plate. You may skip this step if this is the case.
    • Carefully flip the console over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the eight 4mm screws on the metal plate with the X-like symbol.
    • Use a plastic opening tool to remove the metal plate with the X-like shape.
    My PS4 Pro 7115, this and more is integrated with the main plate, as noted above, plus there are 10 in this area (not 8), along with 2 over the fan and 1 to the edge of this area. Model CUH-7115B
  12. PlayStation 4 Pro Fan Replacement: шаг 12, изображение 1 из 3 PlayStation 4 Pro Fan Replacement: шаг 12, изображение 2 из 3 PlayStation 4 Pro Fan Replacement: шаг 12, изображение 3 из 3
    • Use a Phillips #1 screwdriver to remove the four 13mm screws on the X-shaped metal plate underneath.
    • For 7200-series models this is instead a S-shaped metal plate with 2 screws.
    • Grip the X-shaped retaining bracket and lift straight up.
    Mine had an S shape with two screws.
    Christopher - Ответить
    Depending on the series it will have either a S or X shape bracket
    Jeremy Ivey -
    My PS4 Pro 7115 has an S-shaped bracket with 2 screws. Model CUH-7115B
    I have heatsink issue 7016 (x-shaped). However I am only able to find S shaped heatsink plate (71xx model) in my country. Does anyone know how the heatpipes travel within the heatsink? I basically need to drill 2 more holes and thread it to put the x clamp. Also the hole and thread size would be helpful.
    rn nr - Ответить
  13. PlayStation 4 Pro Fan Replacement: шаг 13, изображение 1 из 2 PlayStation 4 Pro Fan Replacement: шаг 13, изображение 2 из 2
    • Grip the edge of the motherboard and slowly lift upwards to remove it from the device.
    • For reassembly, use this guide to reapply thermal paste between the motherboard and the metal plate underneath.
    Does anybody know the name of the white detail from the first screenshot step #13? (Plastic with square metal inside). I broke it by accident during dissembling and want to find replacement for it, but can’t find it anywhere.
    serjgord - Ответить
    I can read F2-4 >POM< on the plastic piece but i guess thisis a radiator/thermal dissipator support. HTH
    Vincent Bee -
    Won't you also need a paired optical drive to replace the motherboard? My ps4 got broken some weeks ago and I've found out that I need to replace the motherboard for it to work again, but I keep seeing that you also need a paired optical drive. Is this true? My ps4 pro is a CUH-7216B if that helps
    Jekabs Freimanis - Ответить
    A warning should be before this step that this step detaches from the primary heat sync. The required tools should list the replacement thermal paste at the beginning, not after the step is already to have been completed.
    tut euch selbst den gefallen und tauscht auch alle Wärmeleitpads. (ca 14 stück)
    Jim Bean - Ответить
  14. PlayStation 4 Pro Fan Replacement, Heat Pipe: шаг 14, изображение 1 из 2 PlayStation 4 Pro Fan Replacement, Heat Pipe: шаг 14, изображение 2 из 2
    • Use a Phillips #1 screwdriver to remove the two 6 mm silver screws from the metal plate.
    Where to get the pink stuff from?
    Dark Flo - Ответить
    #1 Philips screwdriver
    Peter - Ответить
  15. PlayStation 4 Pro Fan Replacement: шаг 15, изображение 1 из 2 PlayStation 4 Pro Fan Replacement: шаг 15, изображение 2 из 2
    • Lift the metal plate that is connected to the heat pipe straight up to remove it.
    The second screw is at the right bottom side !!
    mobilas77 - Ответить
  16. PlayStation 4 Pro Fan Replacement, Fan: шаг 16, изображение 1 из 3 PlayStation 4 Pro Fan Replacement, Fan: шаг 16, изображение 2 из 3 PlayStation 4 Pro Fan Replacement, Fan: шаг 16, изображение 3 из 3
    • Use a Phillips #0 screwdriver to remove the two 6mm screws on the fan.
    • On 7200-series models these screws will be on the right of the fan.
    • Grab the fan and lift up to remove it.
    Screw position indicated is slightly wrong. Both screws are on the right side of the fan. The one on the right is in the correct place. The other is below it rather than to the left as indicated.
    Paul Swinglehurst - Ответить
Заключение
110 участников успешно повторили данное руководство.
Thomas
Участник с: 04/26/17
3 877 Репутация
Автор 5 руководств
Команда
Cal Poly, Team S21-G5, Livingston Spring 2017 Участник Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 членов
Автор 49 руководств
13 Комментариев
Danke für die Anleitung. hat alles super geklappt. Bloß beim letzten Schritt ist die Schraube vom Lüfter nicht oben links sondern unten rechts. Mfg
Camorrista31 - Ответить
Thanks for the guide. Very comprehensive.
I’m clueless with electronics but my PS4 was on its death throes with overheating. I read this guide and watched the video (coffee break included) and got to work. The only trouble I had was that my husband (he’s a good guy normally) decided to help and used too big pliers and broke the connector between the power supply and PS4. Ok, so 5 days wait for replacement. I replaced the fan, thermal paste, and pads and put it back together (shaking like a leaf in a hurricane). It’s quiet and works thanks to ifixit.com. Thank you so much!
K. Birks - Ответить
This was super helpful! For the power supply, I was trying to pull at the socket the cable was plugged into (same color plastic). I think it would have worked better just wiggling the cable.
Also, T8 worked fine, but putting it back together, I noticed T9 was better fit, so if you have a T9, use that instead. After cleaning and repasting, it’s so much quieter. Thanks!
Phil - Ответить
Great guide. I did have a little difficulty getting the power supply connector removed, but I tried to be patient and eventually got it. Thanks!
JTG - Ответить
This is perfect, I love pictures instead of video.
For the PS cable to the MB, I used a small flathead screwdriver on the top of the plug, there is a bit of a lip there allowing me to make small twists to pry the plugout.
Once the plug started to move it came right out.
If there was a picture of the plug out of the port, it would have made it easier for me, at first I was unsure what I was trying to unplug.
fjreoespt - Ответить
tak, jeg brugte guiden til at rense min blæser, som næsten var helt blokeret med støv, og derfor larmet som et jetfly.
Nu køre min PS4 uden larm igen:)
men jeg forstår ikke at sony, har bygget PS4 så man skal skille den helt af for at rense blæser, virkeligt dårligt bygget.
så derfor rart med denne guide.
ps. mit PSU stik sad også meget fast, så jeg tog stikket i boardet, da det er nemmere at få godt fat i.
Svend Viborg - Ответить
I just completed this on my ps4 pro cuh7015b. Disconnecting the power supply did give me a little challenge. Overall very helpful.
Nick Swan - Ответить
Very easy to follow instructions, helped me clear out a very dusty fan!
jackacon - Ответить
Awesome guide. I'm not very familiar with electronics but I was able to do this pretty easy. Just be easy with the power supply connector, it's alittle tight but just keep at it by hand. DON'T do what I did and grab some pliers!!! I was able to repair the cable I damaged but I was very lucky, as it only broke the casing and not the wire inside.
William Campbell - Ответить
my PS4 pro model 7100 had one of the clips (the right one) behind another sticker. took me a bit to find and remove it. additionally, when trying to remove the power supply, at the top there was an additional screw. it looks like it needs one of those tools that you use to build IKEA furniture (yk the L-shaped kind. I could not find a fitting one and had to give up. this was pretty frustrating
Elfi - Ответить
7200 model, sorry
Elfi -
Very useful for full disassembly, deep clean, and repaste. Thermal paste should be included in supplies list though.
Jesse Campbell - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 51
За последние 7 дней: 367
За последние 30 дней: 1,697
За всё время: 157,595
