Введение
If the device fails to charge or connect to a computer, consider using this guide to replace the USB charging port.
Выберете то, что вам нужно
Flip the device so that the screen faces down, with the back facing up.
Unscrew the four screws with a PH000 screwdriver.
Flip the device over so that the screen faces up, and the back faces down.
Separate the front panel using the Opening Tool on a corner to create an opening.
Run the tool along the seams of the device to open up all the sides.
Use the Opening tool to flip up the black retaining flap on the smaller connector.
Gently lift the cable, parallel to the panel, to detach it.
Use the Opening tool to flip up the black retaining flap on the larger connector.
Desolder the wires from the motherboard. For detailed information, refer to the Solder and Desolder guide.
Use tweezers to gently lift the tape from the wires and plastic.
Use tweezers to gently lift the yellow tape that tapes down the yellow flat cable.
Desolder the flat cable.
Flip the motherboard over to the side so that the grey wire and its solder bead faces up.
Desolder the gray wire from the motherboard.
Еще один человек закончил это руководство.
