Введение
This replacement process calls for soldering electronic components and very steady hands. For more information about desoldering, take a look at this helpful guide.
Выберете то, что вам нужно
Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver, turning the screws counterclockwise.
Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
Lift the device off of the case and flip over the device so that it sits screen side down.
The device is now free from the plastic casing.
Desolder the following components from the motherboard.
Desolder from the motherboard the red wire that connects to the speaker unit.
Desolder from the motherboard the black wire that connects to the speaker unit.
Desolder from the motherboard the gray wire that runs along the edge of the device.
Desolder from the motherboard the red wire that connects to the battery unit.
Desolder from the motherboard the black wire that connects to the battery unit.
The motherboard will now be detached from any wires connecting to the device.
Use tweezers to unstick the medium width yellow ribbon cable from the motherboard.
Use a small plastic opening tool to slide the two small black holding clips off of the white connector to which the medium width yellow ribbon cable is attached.
Use your fingers to gently pull the medium width yellow ribbon cable out of the white connector.
Repeat the last two actions to disconnect the narrower yellow ribbon cable and the wider yellow ribbon cable from the motherboard.
The motherboard and battery will now be detached from any ribbon cables connecting to the device.
Use the PH000 screwdriver remove the four 5 mm screws along the bottom edge of the motherboard, turning the screws counterclockwise.
The motherboard is now detached from the device.
Lift the motherboard out of the device using your hands.
Set the motherboard down on a heat safe surface so that the gray side of the motherboard is face up.
Desolder each side of the USB port where it is attached to the motherboard.
The USB port will now be loosened from the motherboard.
Using tweezers, pull the USB port straight out from the motherboard without wiggling it up, down, or side to side.
The USB port is now replaceable.
