Pool Screen Replacement
Выберете то, что вам нужно
  1. Pool Screen Replacement, Damaged screen area: шаг 1, изображение 1 из 1
    • Locate the damaged area on your screen. Use this area to remove the rest of the screen. Using an area that is already damaged makes it easier to remove the old screen.
  2. Pool Screen Replacement, Removing the screen and thread: шаг 2, изображение 1 из 2 Pool Screen Replacement, Removing the screen and thread: шаг 2, изображение 2 из 2
    • Use needle nose pliers to pull the rubber screen thread from the pool cage crease.
    • To help remove the damaged screen, pull down on the screen while you are removing the thread of the old screen.
  3. Pool Screen Replacement, Checking for leftover thread: шаг 3, изображение 1 из 1
    • Examine your work. It should match the image as shown.
    • There should be no thread left in the crease of the pool cage. Remove any remaining screen thread with the needle nose pliers.
  4. Pool Screen Replacement, Measuring the screen: шаг 4, изображение 1 из 1
    • Measure the area of the pool cage that needs to be replaced with a new roll of screen. Cut out the needed amount of screen from the new roll.
    • Do not cut the excess screen on the sides of the pool cage; it will be done in a later step.
  5. Pool Screen Replacement, Placing the thread and screen: шаг 5, изображение 1 из 2 Pool Screen Replacement, Placing the thread and screen: шаг 5, изображение 2 из 2
    • Pull the new screen thread from corner to corner, along the crease of the pool cage. Cut any excess thread from the corners.
    • Use a screen roller to press the thread and the screen underneath against the pool cage crease to secure them. It helps to pull the thread and screen tight while rolling over it.
    • The roller pictured is available at any home improvement store. It will be located next to the pool screens and thread.
  6. Pool Screen Replacement, Removing extra screen: шаг 6, изображение 1 из 1
    • Cut the excess screen from the top, bottom, and sides of the pool cage.
    • Be careful when using the box cutter. Always cut away from your body in order to avoid injury.
  7. Pool Screen Replacement, Finishing up: шаг 7, изображение 1 из 2 Pool Screen Replacement, Finishing up: шаг 7, изображение 2 из 2
    • Check the pool cage for any problems with the newly attached screen. The new thread should be pressed firmly into the pool cage, and the screen should be pulled tight so there are no wrinkles.
Заключение
With this guide, you will be able to repair your damaged pool screen. Follow the steps, and you will have a new screen in no time.
Haley Flanigan
Участник с: 01/17/17
121 Репутация
1 руководство автора
Команда
USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017 Участник USF Sarasota-Manatee, Team 1-1, Stewart Spring 2017
USFSM-STEWART-S17S1G1
19 членов
Автор 24 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 22
За последние 30 дней: 93
За всё время: 8,088
