Выберете то, что вам нужно
The manifold assembly cracked and would not let the compressor build up pressure consistently. Both gauges quit working long ago. This manifold has two quick connects and one safety valve
Mounting bracket for the air pump on the left side
Mounting bracket for the air pump on the right side
Pressure hose from air pump to manifold. Secured with one compression clamp to the manifold
Using a pair of End Cutting pliers to cut the compression clamp. Caution so as to not cut or puncture the hose
Remove the clamp from the hose
Remove the Phillips head screw from the left mount
Remove the Phillips head screw from the right mount
Use a flathead screwdriver to push the pressure hose off the nipple on the manifold
Lift the air pump of the compressor tank by slightly sliding it backwards.
Position the air pump so that the remaining hose does not get kinked .
Next is the pressure relief safety valve.
Use a pipe wrench or adjustable wrench whichever may be available. To remove the valve turn the wrench in a count clockwise direction.
Next is the removal of the two Quick connects. Again, use whatever wrench is available and turn it in a counter clockwise direction to remove those.
Manifold with pressure relief valve and two Quick connects removed
Time to remove the manifold. Using a pipe wrench between the manifold and the tank
then turn the complete manifold assembly in a counter clockwise direction
Manifold assembly removed.
Here is teh repalcment manifold. This was the only one that was readily available for this compressor. The only difference between the old one and the replacement is that here is only room for one (1) Quick connect
Purchased the proper clamp for this repair because they were available. The old clamp can definitely not being reused. It should also be possible to use a normal worm drive hose clamp which are widely available
I used a pair of End cutting pliers to compress the end of the clamp. A pair of Combination pliers etc. should accomplish this as well.
Back in business. Manifold replaced and compressor functioning without any further issues.
