Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Removing the CPU of the Power Mac G4 Quicksilver for replacement.
Выберете то, что вам нужно
The handle to open your computer is located on top of the right side panel.
Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
First you want to remove the fan. Remove the two screws on the back of the computer in the upper left hand corner.
You need detach the heat sink from the CPU. Locate the four clamps holding it down, two on each side.
11 участников успешно повторили данное руководство.
