Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
The handle to open your computer is located on top of the right side panel.
Start by removing the screw holding the card to the chassis as shown.
Before lifting the card out, this small plastic tab needs to be pulled back there by releasing it entirely.
With the tab and screw removed, lift the card straight out.
Disconnect both the power cables and IDE cable from the mother board.
Remove these three screws that hold the motherboard fan and modem connector to the chassis.
Remove the four screws shown to free the mother board from the chassis.
Lift the fan shroud and fan straight up and out. Take care to disconnect the indicated connector
Remove the heatsink clamps with a flathead screwdriver and do the same for the other side.
There are 4 pins: remove the 3 pins near the RAM but not the pin nearest You.
You are now ready to slide gently (and without ANY difficult) the motherboard. Lift up and the game is done.
10 участников успешно повторили данное руководство.
