Введение
In order for you to remove components with power supplied to them, you need to remove the power from the device by disconnecting from the main power source.
Выберете то, что вам нужно
Place the device on a firm surface with the device screen facing down.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Using a plastic tool and the plastic card, gently pry off the back cover.
Using tweezers, remove the electrical connector that connects to the battery to remove the power to the battery.
Еще один человек закончил это руководство.
