PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement
Выберете то, что вам нужно
  1. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Battery: шаг 1, изображение 1 из 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Battery: шаг 1, изображение 2 из 2
    • Use your thumbs to push the two battery retaining tabs away from the battery.
    • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
  2. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Memory Door: шаг 2, изображение 1 из 1
    • Remove the three 2.3 mm Phillips screws securing the memory cover to the lower case.
  3. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 3, изображение 1 из 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 3, изображение 2 из 2
    • Lift the memory cover slightly and pull it toward yourself to remove it from the lower case.
  4. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement, Upper Case: шаг 4, изображение 1 из 1
    • Remove the following ten screws:
    • Two 14.7 mm shouldered Phillips.
    • Three 12.3 mm Phillips.
    • One 3.8 mm T8 Torx.
    • One 6.8 mm T8 Torx.
    • Three 1.3 mm Phillips.
  5. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 5, изображение 1 из 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 5, изображение 2 из 2
    • The ZIF cable is located underneath the bottom RAM slot. If your PowerBook has both RAM slots occupied, make sure to remove the RAM chip.
    • Use your fingernails to separate the ZIF cable lock away from its socket. (Move the two brown bits down 1mm)
    • The ZIF cable lock will move about a millimeter away from the socket before it stops (see picture 2). Do not try to remove the ZIF cable lock.
  6. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 6, изображение 1 из 1
    • Use the tip of a spudger to slide the trackpad ribbon cable out of its socket.
  7. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 7, изображение 1 из 1
    • Remove the four 3.4 mm Phillips screws from the PC card side of the PowerBook.
    • When replacing these screws, you must reinstall each screw in the correct order. Begin by installing the screw closest to the display hinge, and go out from there.
  8. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 8, изображение 1 из 1
    • Remove the four 3.4 mm Phillips screws from the DVI connector side of the PowerBook.
    • During reassembly, make sure to reinstall the two screws on the right into their appropriate locations, and not the DVI port anchor holes.
  9. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 9, изображение 1 из 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 9, изображение 2 из 2
    • Depress the display latch release button and open your display.
  10. PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 10, изображение 1 из 2 PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Upper Case Replacement: шаг 10, изображение 2 из 2
    • Starting near the display, lift the upper case straight up off the lower case, minding any cables that may get caught.
Заключение
Прикрепленные документы
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 4,190
