Propel Gyro-X On-Board Battery Pack Replacement
Выберете то, что вам нужно
  1. Propel Gyro-X On-Board Battery Pack Replacement, Bottom Propellor Blades: шаг 1, изображение 1 из 1
    • Remove the two 5.0 mm Phillips #00 screws from the rotors.
    • The blades will fall off when the screws have been removed.
  2. Propel Gyro-X On-Board Battery Pack Replacement, Outer Shell: шаг 2, изображение 1 из 1
    • Locate the nubs on either side of the helicopter.
  3. Propel Gyro-X On-Board Battery Pack Replacement: шаг 3, изображение 1 из 1
    • Pull the body shell off of the nubs on both sides.
  4. Propel Gyro-X On-Board Battery Pack Replacement: шаг 4, изображение 1 из 2 Propel Gyro-X On-Board Battery Pack Replacement: шаг 4, изображение 2 из 2
    • Push the front of the nose back towards the tail of the helicopter.
    • Push down on the shell and pull it away from the body, so that both slots pass over the hooks on the bottom of the helicopter.
  5. Propel Gyro-X On-Board Battery Pack Replacement, On-Board Battery Pack: шаг 5, изображение 1 из 1
    • Do not cut battery wires simultaneously because this will cause a short circuit. Due to the unrestricted flow of electricity, a short circuit could cause bodily harm.
    • Pull the battery off of the holder.
    • Cut each of the wires to the battery one at a time using a pair of wire cutters.
    • To replace the battery, you will need to strip both of the wires from the circuit, and both of the wires from the battery. You will then need to twist and solder both pairs of wires(red to red, black to black). You can find directions on soldering here.
    • Once the wires are cut, strip and solder the wires connected to the Gyro-X to the wires of the new batter pack.
    • To learn how to solder follow the steps below How To Solder and Desolder Connections
Заключение
4 участников успешно повторили данное руководство.
Jack Jenner
Участник с: 04/08/15
293 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 17-2, Forte Spring 2015 Участник Cal Poly, Team 17-2, Forte Spring 2015
CPSU-FORTE-S15S17G2
4 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 3
За последние 30 дней: 19
За всё время: 3,076
