Введение
This guide provides instructions for the removal and re-installation of the drone L.E.D. bulbs. This guide requires soldering. Please see this guide for more information on how to solder and desolder connections.
Выберете то, что вам нужно
Remove the eight (8) 5mm Philips screws attaching the motor arms to the body using a Philips J00 screwdriver.
Remove the six (6) 5mm Philips screws attaching the Body Cover to the Body of the drone using a Philips J00 screwdriver.
Remove the Body Cover.
Remove the two (2) 5mm Philips screws attaching the Motherboard to the body of the drone using a Philips J00 screwdriver.
Lift the Motherboard off the mounting position.
Prepare and warm up a soldering iron.
Position Motherboard so that the L.E.D. bulb solder joints are accessible.
Use the soldering iron to melt the solder joints.
Remove the L.E.D. bulb from the Motherboard
