Выберете то, что вам нужно
Orientate the drone to where the black side of the drone face upwards.
On the bottom side of the drone, remove the twenty-two 5mm Phillips #1 screws holding the black frame to the body.
There is one screw under the rear light. Pry the opaque cover to access the last screw.
From the front of the drone, the left motor has red and blue leads.
From the front of the drone, the right motor has white and black leads.
Remove the leads from their points on the motherboard with a soldering iron, respective to each motor.
