Pyle Astro PTBL7C LCD Replacement
Выберете то, что вам нужно
  1. Pyle Astro PTBL7C LCD Replacement, LCD: шаг 1, изображение 1 из 2 Pyle Astro PTBL7C LCD Replacement, LCD: шаг 1, изображение 2 из 2
    • Using the plastic opening tool, work your way along the edge of the tablet.
    • The display is held in place by plastic tabs which slide into recesses in the rear plastic panel.
    • Once all clips are released, gently open and separate the front display assembly and the rear plastic panel.
    • Place the front display assembly facing front side down to expose the inside.
  2. Pyle Astro PTBL7C LCD Replacement: шаг 2, изображение 1 из 2 Pyle Astro PTBL7C LCD Replacement: шаг 2, изображение 2 из 2
    • Remove the three 4 mm JIS #0 screws to release the PCB board.
  3. Pyle Astro PTBL7C LCD Replacement: шаг 3, изображение 1 из 1
    • The display is held in place by plastic tabs which slide over the outer edges of the backside of the display.
    • Gently work your way around the display while pulling the plastic tabs back to release the LCD display from the front panel.
  4. Pyle Astro PTBL7C LCD Replacement: шаг 4, изображение 1 из 1
    • Once all clips are released gently open and separate the front plastic display from the LCD and place the LCD face down.
    • The front plastic display contains the external touch panel, and the capacitive touch screen overlay.
  5. Pyle Astro PTBL7C LCD Replacement: шаг 5, изображение 1 из 1
    • Using both hands, gently release the ribbon cable to the capacitive touch screen overlay from the PCB board by pushing both gray tabs outwards.
  6. Pyle Astro PTBL7C LCD Replacement: шаг 6, изображение 1 из 1
  7. Pyle Astro PTBL7C LCD Replacement: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Plastic Cards
    $2.99
    Купить
    • Using a plastic card, gently remove the adhesive that holds the battery in place and separate the battery from the LCD panel.
    • Exercise extreme caution and be sure to not rupture the battery casing.
  8. Pyle Astro PTBL7C LCD Replacement: шаг 8, изображение 1 из 1
Заключение
Andrew Redifer
Участник с: 03/27/18
265 Репутация
Автор 2 руководств
Команда
IUPUI, Team S3-G6, Harley Spring 2018 Участник IUPUI, Team S3-G6, Harley Spring 2018
IUPUI-HARLEY-S18S3G6
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 6
За последние 30 дней: 11
За всё время: 286
