Quasar Microwave Capacitor Replacement
Выберете то, что вам нужно
  1. Quasar Microwave Capacitor Replacement, Disassembling Quasar Microwave Outer Cover: шаг 1, изображение 1 из 1
    • Disconnect the power supply cord from the outlet.
    Спросите у FixBot
  2. Quasar Microwave Capacitor Replacement: шаг 2, изображение 1 из 2 Quasar Microwave Capacitor Replacement: шаг 2, изображение 2 из 2
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
    Спросите у FixBot
  3. Quasar Microwave Capacitor Replacement: шаг 3, изображение 1 из 2 Quasar Microwave Capacitor Replacement: шаг 3, изображение 2 из 2
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
    Спросите у FixBot
  4. Quasar Microwave Capacitor Replacement: шаг 4, изображение 1 из 3 Quasar Microwave Capacitor Replacement: шаг 4, изображение 2 из 3 Quasar Microwave Capacitor Replacement: шаг 4, изображение 3 из 3
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
    Спросите у FixBot
  5. Quasar Microwave Capacitor Replacement, Capacitor: шаг 5, изображение 1 из 2 Quasar Microwave Capacitor Replacement, Capacitor: шаг 5, изображение 2 из 2
    • Old electronics collect dust, no matter if they are in active use or being stored. It is recommended to clear out some of the dust prior to affecting any complicated repairs. Use compressed air, and wear a dust mask and goggles. Always use precaution when working with old electronics.
    • The capacitor stores a small amount of electrical energy. Discharge capacitor by placing a screw driver across the terminals. Use a screwdriver with a non-metallic handle and a shaft that is longer than 4” (10.75mm) Touch the metal shaft of the screwdriver simultaneously to both metal terminals of the capacitor. There should be a spark.
    • If the capacitor sparks, you can stop reading here. The spark indicates that the capacitor is working properly. If the capacitor does not spark, read on to Step 6.
    Спросите у FixBot
  6. Quasar Microwave Capacitor Replacement: шаг 6, изображение 1 из 1
    • Place the multimeter on resistance mode and test the resistance of the capacitor.
    • If the resistance increases/decreases, the capacitor is working fine. If the resistance of the capacitor reads 0 or over several kilo ohms, the capacitor needs to be replaced.
    Спросите у FixBot
  7. Quasar Microwave Capacitor Replacement: шаг 7, изображение 1 из 3 Quasar Microwave Capacitor Replacement: шаг 7, изображение 2 из 3 Quasar Microwave Capacitor Replacement: шаг 7, изображение 3 из 3
    • Tip the microwave back so it is lying face up. This allows access to the screws beneath the transformer.
    Спросите у FixBot
  8. Quasar Microwave Capacitor Replacement: шаг 8, изображение 1 из 2 Quasar Microwave Capacitor Replacement: шаг 8, изображение 2 из 2
    • Locate the transformer. The capacitor cannot be removed without removing the transformer first.
    • Locate and unhook all wires connecting the transformer to the rest of the microwave.
    • Take note of where each wire connects before disconnecting. Wiring a microwave incorrectly can cause serious damage.
    Спросите у FixBot
  9. Quasar Microwave Capacitor Replacement: шаг 9, изображение 1 из 1
    • Remove the four exterior screws securing the transformer to the microwave frame.
    Спросите у FixBot
  10. Quasar Microwave Capacitor Replacement: шаг 10, изображение 1 из 3 Quasar Microwave Capacitor Replacement: шаг 10, изображение 2 из 3 Quasar Microwave Capacitor Replacement: шаг 10, изображение 3 из 3
    • Remove the transformer.
    Спросите у FixBot
  11. Quasar Microwave Capacitor Replacement: шаг 11, изображение 1 из 2 Quasar Microwave Capacitor Replacement: шаг 11, изображение 2 из 2
    • The metal band locking the capacitor in place can now be accessed. Locate and remove the screw securing the the metal band.
    • Lift the metal band off the capacitor.
    Спросите у FixBot
  12. Quasar Microwave Capacitor Replacement: шаг 12, изображение 1 из 3 Quasar Microwave Capacitor Replacement: шаг 12, изображение 2 из 3 Quasar Microwave Capacitor Replacement: шаг 12, изображение 3 из 3
    • Remove the capacitor.
    Спросите у FixBot
  13. Quasar Microwave Capacitor Replacement: шаг 13, изображение 1 из 1
    • You can now install a replacement capacitor.
    • Repeat all steps in reverse order to install a capacitor in a Quasar Microwave MQ7774XW (1984).
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Michael
Участник с: 09/26/12
237 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 2-12, Propen Fall 2012 Участник Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 членов
Автор 12 руководств
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 18
За последние 30 дней: 120
За всё время: 7,448
