Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Before recalibrating the battery, charge the battery to 100%. Take a note of the initial data.
Use your laptop while it is discharging. You will want to do this until the computer shuts down, and if you are using Windows turn it on again until the laptop no longer turns on; this ensures a full discharge.
Every laptop has a different charge indicator. When your laptop is fully discharged, plug it in immediately. Fully charge the laptop.
Once you are finished, check the BMS data. The reported data should be corrected.
Run Command Prompt as an administrator. Enter powercfg /batteryreport.
When the report is ready, you will receive a message stating where it is located. Check the data for consistency.
Plug the laptop in and turn it on; unplug it once it is on. Press ESC and select System Diagnostics.
Open the Component tests submenu. Select Memory or Hard Drive.
Select Extensive test. Choose Loop until error.
When the laptop shuts off, immediately recharge the battery.
Boot the laptop into a live Linux Mint Cinnamon session. Open Settings and make the following changes:
Open Power Management. Change When the battery is critically low to Do nothing.
Use the laptop until it shuts down. Everything from this session will be lost.
Plug the power adapter into your laptop. Allow POST to finish before unplugging the laptop.
Disconnect the laptop once the laptop is booted. Finish discharging the battery.
Note the date of the recalibration.
Note the original charge capacity (Designed capacity).
Note the current capacity of the battery (Full charge capacity).
14 участников успешно повторили данное руководство.
4 Комментариев
Did not help at all.
I have a Windows tablet, pretty old one - previously it was showing 39% battery wear (it actually was holding for about an hour, battery itself is a bir inflated).
A couple days ago it hard crashed and wear level was reseted to 0%. Now some weird stuff started: turning off when reaching 14% battery charge, screen dimming etc.
Tried this method, and as I said in the beginning - it did not help, still shows 0% wear.
Late response, but some laptops and Windows based tablets (notably HP) always show 0% wear in Batteryinfoview. You need to go into the UEFI diagnostics or use use HP Support Assistant and grab it from the advanced data on HP. If it’s Dell, UEFI SupportAssist (newer systems) or ePSA (legacy).
Nothing to worry about, but another quirk like the EOL capacity reporting response on some Dell batteries. Added a note in the quirks section about this.
Nick -
I’m curious, can we send command through the I2C interface from the laptop itself to the battery and do some calibration from there? is the built-in BMS has the capability to do that?
May battery charging shows 39% and it should be always plug in (windows 11) on Asus laptop.
