Выберете то, что вам нужно
take out the sim tray
unscrew the two pentalobe P2 screws under the phone
use a suction cup and a pryer to open the phone(Very Heavy!)
unplug the power cable. it should be attached just by pushing , so just lift it.
unplug the screen cable. they are ZIF connectors.
you can test the new screen here, just by plugging the new screen cable, then the power cable
unplug the button cable, also ZIFs.
remove the battery using a hard rubber spatula.(it's got handle like IPhone's, but with china quality)
pry from the left bottom side. NEVER from the right side, or you might damage a cable.
remove the remaining glue from the battery, and re-tape it inside the white lines with tapes like TESA 2mm.
unplug antenna wire running down right side of phone to bottom mainboard.
remove these phillips #0 screws on the upper board(forgot the number and the place, please add)
remove the vibration motor cover
remove the upper motherboard
remove the phillips #0 screw from the lower casing
they're black, so easy to recognize
unplug all connectors(need photo)
use a hair dryer to heat the lower board(it's got glue)
be careful not to use force, the board is very fragile. If you feel hard to remove, heat it again.
Heat the borders of your screen to loosen the glue.
use a suction cup to open it.
the cables from the screen should all be detached at this moment
remove all the remaining glue from the plastic bracket (I mean all)
use tapes like TESA 2mm to re-glue the bracket.
you'll need to glue all the borders, but not around cameras, speakers, and proximity sensors.
Check the video I've linked to see where to glue.
12 человек успешно провели ремонт по этому руководству.
7Комментарии к руководству
Where's the video? I can't find it on this page.
Redmi Note 4 lcd Jumper ways
Please!
Where can I find the replacement screen for this model??
The screen I ordered have the connectors the wrong place and I can't find any replacement screen with BOTH wires on the bottom …
you could buy a new screen in taobao
牛头与画像 -
do you have like a procedure how to replace the adhesive tape under the battery. My phone’s battery is loose, you can feel it move when you shake the phone.
Ha ha, its very heavy. In my case i unglued cracked screen instead open it. need to be very careful and help wit plastic tools.
Alex Derkach - Ответить
