Введение
This guide will show you how to remove the processor on your HP Compaq dx2000MT.
Выберете то, что вам нужно
Turn off your computer and remove the power cable by pulling it straight out of its socket.
Remove the side case door by pushing towards the rear of the device with your hand.
Once you slide the door back, remove it by pulling it outwards from the device.
Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
Remove the other 2 Torx T15 screws holding the other side of the drive in place.
Remove the IDE data and power cables from the hard drive.
Remove the front bezel by pulling upwards and out from below the lowest air vent.
Remove the following screws:
Front Torx T15.
Torx T15 mounting the hard drive cage to the optical drive bay.
Fully remove the hard drive cage by sliding it towards the back of the device and pulling down.
Proceed to the other side of the hard drive cage.
Remove the two Torx T15 screws holding this side of the hard drive in place.
Remove the hard drive from the hard drive cage by pulling it outward from the cage.
Remove the 3 prong power connector from the motherboard by pulling it outwards toward the side of the device.
Remove the 4 push fasteners from the case by:
Prying them outwards with a small flathead screwdriver and
Pulling them out with tweezers or plyers.
Remove the 4 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
Remove the 20 pin ATX power connector from the motherboard by pressing down the holding latch and pulling out towards the side of the device.
Slide the power supply towards the front of the device
Then pull the power supply down and remove it from the case.
Remove any IDE cables from the motherboard by pulling them out towards the side of the device.
Remove the 2 prong speaker connector by pulling out towards the side of the device.
Remove the 16 pin connector from the motherboard by pulling it out towards the side of the device.
Remove the 14 pin USB connector by pulling it out towards the side of the device.
Remove the 3 pin power connector by pulling it out towards the side of the device.
Remove the cpu cooler by pulling out towards the side of the device.
We have a guide for reapplying thermal paste that makes this easy.
3 участников успешно повторили данное руководство.
