Введение
This guide is designed to help solder any wires that may be broken. Soldering irons are somewhat dangerous to handle due to the extreme heat, so exercise caution when soldering. It's also very important to keep the thick white connector from breaking, so when opening the side panel, keep the device close to the panel until the connector is safely removed.
Выберете то, что вам нужно
Turn the video camera upside down so the bottom of the device is visible.
Pull back the tab that is holding in the battery in place and remove the battery from the device.
Use tweezers to carefully pull out the circular stickers to reveal the 4mm screws.
Use a thin plastic pick to pry off the side of the device and carefully remove the display.
Carefully remove the side face from the device. Avoid pulling on the white connector.
To remove the side face entirely, find the large white connector, flip open the grey lip with tweezers, and gently remove the white connector.
