This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Введение
Here's how to fix one of the most common failures on ghd straighteners
Выберете то, что вам нужно
Видео обзор
lift the round covers slightly with your finger to make a small opening.
Insert a thin flat screwdriver, or a lever if you have one in this opening.
Lift by trial and error to avoid breaking the teeth of these fragile covers. If they break, don't panic, you can glue them.
Sometimes these screws are mounted with screw glue. The best is to bring two screwdrivers, including a small one for better control.
Start by unscrewing the screw: By having the first fixed screwdriver on one side, and the other which unscrews on the other side.
screw it out, push the shaft and take it out.
Push the plastic axle with your screwdriver and take it out.
Remove the spring.
Remove the two screws from the button side cover.
Remove the cover equipped with the button.
The electronic card is now accessible. You can test the thermal fuse if you wish.
Unscrew the 4 screws that hold the plate to the electronic board.
The thermal fuse is now accessible.
To remove the HS fuse, slightly pull out its cables as shown in the photo.
Using small pliers, scissors or nail clippers, cut the two cables.
You can now easily pull out the fuse head and cables on the other side.
Insert the 2 cables of the new thermal fuse.
Lift the tab and insert the fuse head.
Pull the two cables and press on the head to firmly press the fuse against the ceramic plate.
Refit the plate on the electronic card using the 4 screws.
Do not forget to put the silicone part, which protects the electronic card against heat.
Refit the cover fitted with the button using the two screws.
Connect the straightener cable
You can now test the operation.
If you have a thermometer, the temperature should be between 180°C and 190°C. If you don't have it, turn on the straightener and let it heat up for 5 min to make sure everything is fine.
You can now reassemble everything:
First the spring, then the plastic axle, then the metal axle and finally the screws/washers and covers.
To reassemble your device, follow the steps in reverse order.
3 участников успешно повторили данное руководство.
Особая благодарность этим переводчикам:
81%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
