Выберете то, что вам нужно
Remove the eight screws holding the wood-patterned cover to the microwave frame.
The first four screws are located on either side of the microwave front.
Remove the additional four screws securing the wood-paneled case to the microwave frame.
Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
Lift the case upward slowly until the case is free of the microwave.
Observe the lever mechanism found just behind the door handle, inside the microwave.
Lift up on the outside lever.
Push up on the white plastic piece.
Push metal bar down, snapping the white plastic piece above it.
This is how the fixed mechanism should look.
Press the button and enjoy your newly fixed door!
Еще один человек закончил это руководство.
