Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Before disassembling your Atari Lynx, be sure the device is powered off.
Remove any game in the console by opening the right latch and sliding the game to the right.
Remove the four 35 mm Phillips #1 screws at each corner of the backside on the Atari Lynx.
Pinch the rear panel with your fingers and lift away from the Atari.
Remove the battery panel by pinching the sides with your fingers and lifting it away from the Atari.
Remove the control panel by pinching the sides with your fingers and lifting it away from the Atari.
Remove the logic board from the console.
Flip the logic board so the screen is facing down.
Now you will need to desolder both of the wires connected to the speaker.
If you are having trouble desoldering, click here.
Finally solder the new speaker back on and follow the previous steps in reverse order.
4 участников успешно повторили данное руководство.
2 Комментариев
What are the specs on the speaker? Size? Wattage?
