Введение
Follow the steps in this guide to replace your broken central fan in your projector.
Выберете то, что вам нужно
Pry the sides of the case off using your fingers.
Pop the tabs connecting the rest of the case together by running your fingers underneath the edges.
Remove the metal plate covering the circuit board by removing the four Phillips screws.
Remove the single Phillips screw on the circuit board.
Gently pull up on the circuit board to remove it.
Remove the two Phillips screws.
Lift up on the black plastic casing around the light bulb and remove it from the projector.
Disconnect the power supply from the light bulb by gently pulling on the two metal tabs attached to it.
Remove the three screws circled in red that are holding the heat sink to the bottom part of the case.
Remove the Phillips screw.
Slide the plastic piece on the left side of the fan out of its position.
Remove the two connectors holding the fan to the metal frame.
Insert a flat head screw driver or other prying tool under the head of the connector and gently pry up.
Insert the new fan in place of the old one.
3 участников успешно повторили данное руководство.
